2005 Weak Differential
I keep reading about the 2005 having a weak differential. Our car is stock with a six speed. At what power level does the differential start giving up the ghost? I don't know anyone personally who has had a problem.
My 05 is at nearly 134k and I have my original differential. I believe this issue has more to do with hard accelerations like burnouts and racing. From I have read, the crack/break occurs from the stress or torque caused on hard acceleration. I have not heard of anyone having the break because they just casual drive.
Mine was replaced under warranty, not because it broke, but because it was noisy. The new one is just as noisy and always has been. I have somewhere between 125,0000 and 150,000 (not sure exactly w/o looking through the paperwork) on it. Knock-wood, it's just fine.
lisa
lisa
The problem usually was evident when drag racing…yes the diffs would crack etc. I do not drag race (street or organized) and have a Lingenfelter set up and have had NO problems. My C6 is a 2005 and still running strong with no problems
Oh, I forgot to mention it, but I have an LS3 under the hood, now. 15,000 mi. and counting.
lisa
lisa
I've been "slightly" above stock hp since the car was new and for years I hoped as long as I had traction limited tires I'd be ok. Never once had wheel hop but one day under spirited excelleration I cut the diff in half. I can only assume a slight crack may have occurred before the carnage actually happened. Main shaft and one exhaust can destroyed. My guess is a majority would never have a problem.
Some call it driveline shudder but I dare say you will find it is wheel hop as with the old Chevelles of the day. A friend broke his 12 bolt rear end from excessive wheel hop. That is one sturdy piece but the violent action does violent things. I'm not on the drag strip so doubt that I will have any problem and have yet to encounter drive line shudder or wheel hop. I was just wondering about problems guys might have on the street. Thanks for the responses.
ok I must say after reading this topic an some of your responses im a lil concerned I just bought a base 6 speed 05 with headers procharger an exhaust had it on dyno an its putting out close to 600 to the rear wheel I don't know if anything has been done to the diff, what is the cost to upgrade or replace that?
Sorry I was talking to the OP. If I were you, I would worry.
You first have to drive like an azzhat for that to happen or track it.
