Cluster repair
Cluster repair
Hello to all! Anyone knows someone who repair clusters? I have a 2005 cluster and none of the analog gauges are working, gas, odo, battery etc.... Everything else, all lights and messages display still works. All information still can be seen on the HUD display. I want to know if its worth to repair it.
Up
Could be as simple as a loose connector.
When all else fails, pull the gauge cluster and check the connectors. If the problem is up line in the cluster, at least you have the cluster out to start tracing it to find the problem.
I agree, and the fact that all the gauges are out makes me think it is a simple solution. If only one gauge was not working, I would expect a more involved fix.
Race Car Tech
If it's not the connectors, then US Speedo dot com fixes clusters.
