My Vette Punished me for taking Her to the Track
First time with the car at the track, 3rd run of the day and when I slammed it into second I heard what sounded like bolts dropping out the bottom of the car. Now she shudders HARD when taking off in first gear, but seems to drive OK after you get going. I'm thinking either the clutch is shot or I sheared off a bolt on the flywheel or something. Thoughts?
Thoughts are you need to get that puppy stripped down! Somewhere along the job you're gonna find the problem. If it's the first time you've dropped the drivetrain you are in for some real fun!
If you diy this you are gonna build such a bond you'll never treat it so rough again! Trust me
Good luck, keep us updated.
LA
LA
Is yours an 05? Have you read up on the know flaws with the 05 Diff housing? i believe its the right side of the case has a major weak spot and is know the literally split the case there when pushed hard. A flaw know by Chevy, resulting in them coming up with a whole new diff for all 06 and up. The new diff has a different bolt pattern, which is why many of us 05 owners my self included get a conversion to run the newer 06 and up diff. if you have an 05 grab a light and see if you can get under to inspect the diff. when the case sheers some times it doesn't completely come apart and causes a lot of internal damage which could be the source of you're issues.
LA
LA
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
What you would be looking for is a broken casing and you would have exposed gearing maybe even gear oil dripping, so if you didn't see anything obvious, the problem is somewhere else.
