need help 2008
I can't believe I'm actually taking the time to write a response, but instead of having us tell you what you may or may not have, just look to the right and left of your ashtray in the center stack. If you see buttons, you have heated seats. If you see buttons/*****/joysticks on your passenter seat near the door sill, you have a power passenger seat.
As far as your fuel smell, someone else with experience in that situation will have to chime in or we'll need more detail.
As far as the starting issue, you may have a bad alternator, battery, starter. My money is on battery. Again, someone with more expertise may want to chime in.
Take your vin to a dealer and they can tell you. Some vendors on here can do likewise. With what you said it has, sounds like a 3lt. Leather wheel and some inside components will make it a 4lt. You can also join the NCM and they can sell you a window sticker for your vin - good way to support the Vette experience!!
RPO CODE decal on the glove box will tell you what trim level: 3LT in the third column from the left; bottom code
