How to remove Targa Top seals and hardware
I absolutely did a search, then an advanced search, then again...just get a laundry list of posts with everything under the sun...
Would greatly appreciate any help pointing me to a good thread or reference to remove the C6 targa top hardware and seals.
CHEERS and MERRY CHRISTMAS and THANK YOU!!!
The latches are easy. You need a torx bit as far as I remember for the front ones. The weather strips on the sides are held by 4 or 5 Phillips screws tucked under the rubber. Some of them are VERY tight (they were on mine) so use a good screwdriver. Pretty simple.
