It lives! There is life after death
2008 C6 / A6 LS3, F55,
427CI, ERL LS3 Superdeck B&S 4.125X4000
Built 6L80 Trans
Haltech CAI
AR headers / x-pipe no cats, coated by Dynapar
25% ATI underdrive pulley
3800 triple disc stall Circle D
Fast 102 intake ported
60# injectors
LSA heads, ported & flowed
Patrick G custom grind camshaft
.660 Brian Tooley Springs
SS valves
3.42 Z06 rear diff
Dewitt radaitor & fans
B&M transmission cooler with fan and therm, passenger front fender
B&M oil cooler with fan and therm in drivers front fender
P-fadT trans mounts / Hinson engine mounts
Subfloor’s, custom transmission / rear diff brace
Oil catch can
electric exhaust cut outs
Carbon fiber drive shaft
Dyno matt sound deadening throughout car
New upgraded speakers, Pioneer head unit.
Reverse camera
Front Curb Alert
Pfadt drag pac coil over suspension
Pfadt drag sway bars
Seats covered in high grade leather
Armrest covered in leather
Blue LED installed in the front fenders to back light the side vents
Brake calipers painted Blue
Blue gorilla wheel locks
Forged wheels, 18x12 rear and 18x10 front
Rear tires 345/35-18 M/T drag radials
Front tires 295/35-18 Nitto Invos
Paint ( Corvette black with blue metal flake, 4 coats of PPG clear )
Paint is blocked and slicked out with 5000grit sand paper
Hood vents that function
Bumper vent also functions
Front and rear corvette emblems removed
HUD installed
Interior lights are blue LED
New 5 point Wolf cage
Blue Crow 5 point safety harnesses
TOP OF THE LINE SECURITY SYSTEM! If the car moves a foot it will call me and I will come running with my .40cal. Even if you cut out the battery it will still call me! I can also shut the car off from the phone. Just in case some scum bag reads this and gets a silly idea.
From this
To a Supervette
Built 6L80 Trans
Haltech CAI
60# injectors
SS valves
3.42 Z06 rear diff
Oil catch can
Reverse camera
Front Curb Alert
HUD installed
From this
To a Supervette
One sick looking ride!! Looks phenominal all blacked out.
What did you use to black out the headlamps?
What side skirts are those?
Why did you go with 18s all around vs and 18/19 set up?
Thanks.
Thanks.
Anything can be stolen but it would be easier to take the fuel pump than it would be to get at the back up battery. I also put enough insurance on it to cover the cost of buying and building another one. One of the best things about living in Texas is that you are allowed to use deadly force. You can shoot someone for being in your yard at night and it is legal.
The skirts are from Supervette
I went with 18" wheels so I would have more sidewall to absorb the shock of the stall at the drag strip. I also picked them because the best priced 345 tire is the BFG drag radial. When these M/T drag radials are gone I will switch to BFG drag radials. I have a heavy foot and tend to wear out rear tires pretty quick. Two BFG's cost around 300-350 dollars.
The car looks insane in the sun because it changes colors as you walk around it. Right now it is over cast and 35-37* out so it does not show. I took a walk around video and I will try to figure out how to upload it.
No one makes that hood vent! But I can tell you how to do it.
I did not care for the aftermarket hoods and I did not want to be like everyone else so I founds some Mustang hood vents and we cut my factory hood and inserted them. They are 100% functional and the vent the header heat from under the hood. I still need to cut the corvette heat shield material that is clipped under the factory hood but I need to figure out a real clean way to do it and make it look factory.
THAT IS ONE BAD *** LOOKING CAR and I don't usual like a blacked vette. I hope that you are healing as well as your car has.
Enjoy and watch out for idiots
Best of luck and congrats on an amazing looking car
Lisa
Lisa
