Locked out
Locked out
Today I pulled a dummy move. Removed my battery from my C6. I closed the hood of the car & the doors. Lucky the window was down enough for me to stick a hanger in & pull the manual lever to open the door. Just wondering if the window was up how would I have gotten into the car??
St. Jude Donor '12
You would use your fob, remove the key from the fob, use the key to open the hatch (there is a key hole near the lights for the license plate), you would then use the pull lever over the driver's side wheel well to open the driver's side door. It is a good idea to ensure that your key actually opens the hatch.
Alternatively, you could call Onstar assuming your car has power and assuming you pay for the service.
Worst case scenario, and this just occurred to me, you could connect and disconnect your battery repeatedly. Each time you do this the window should index down just a little bit. You would do this until you can reach in and manually open the door with the lever next to the seat.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'19
starter
hook your battery charger to the starter cables and use your fob
Received 2,059 Likes
St. Jude Donor '13
If the battery is merely dead, you can connect to the starter cable under the car and a ground, just like you said.
But if the battery has been removed, like OP said, then I don't think this will work; the other end of the starter cable is not connected to anything.
Correct? Or not?
Correct? Or not?
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,831 Likes
2015 C7 of the Year Finalist
Correct? Or not?
Correct? Or not?
My fear would be that with no battery, the battery cables may both be touching a ground and essentially shorting the entire system.
Also, the battery acts as a capacitor which smooths pulsating DC from the alternator or, and I am guessing here, a battery charger. Unless one is sure the charger puts out pure DC then connecting it to my expensive car electronics may not be the best idea.
good for people to know about that key and release in truck.
I quit driving my c6 outside of town because of an intermittent
problem with the ez access. It will not unlock the car sometimes.
Its done it 3 times at the dealership. They have no clue what is
wrong. It does not receive the FOB signal. Just never
felt wanted to get far from home and have to deal with it.
You just kinda wait it out. eventually it will start to work.
Buttons of FOB do not work either. Both FOB's
Thought one time the service advisor was going to just break
the window. Was holding up other cars coming in. ? if some
don't know about the FOB key.
try it
Correct? Or not?
Correct? Or not?
St. Jude Donor '13
I would say that it still might work. Frame is ground so that's covered whether the battery is connected or not. Connecting the charger's positive cable to the positive lug on the starter (where the battery positive cable ends up) should electrically be the same connection.
However, the positive cable is actually TWO cables ganged together up by the battery. As discussed, one cable goes down to the starter. The other one ganged with it goes somewhere, but I never traced it out and so I don't know if it supplies power to something that might let you unlock the doors when the car is otherwise dead. Anyone know what's happening with that?
Doesn't it go to the alternator on the 2nd wire?
Location: BOOMER SOONER Big 12 Champions 2000, 2002, 2004, 2006 - 2008, 2010, 2012, 2015 - 2020.....
Trying to visualize the system in my tiny head, I'm thinking that the cable on the starter goes up to the positive post on the battery. If the battery has been removed like OP said, then the upper end of the starter cable is just hanging in air and can't supply power to anything.
St. Jude Donor '13
Dan-
What I'm trying to say is that if the starter cable isn't connected to anything except the starter, then putting the + lead from your charger can't power up anything except the starter itself.
I think we agree that the negative lead from a charger could go on any convenient ground, or the negative battery terminal itself.
But in order for the positive charger lead to do anything, there must be a complete circuit and the current must flow to someplace in the car that can control the doors. If the starter cable is disconnected from the battery, then you can't have a circuit.
Now, if that other + cable that is ganged to the starter cable, eventually goes to something that will power the BCM and other necessary circuits, then it works. But if the ganged cable doesn't do that, then it won't work.
We've go some real Corvette electrical wizards on this Forum, can't one of them step in and straighten this out?
