Anyone running a 295/30/19 on the front?
Old 02-24-2013, 01:24 PM
TLTONEY
TLTONEY's Avatar
Default Anyone running a 295/30/19 on the front?
Here is the thread that I started in the Wheels and Tire section of the forum.
http://forums.corvetteforum.com/whee...post1583206889
"Hello,
I have been trying to find an answer to this without any luck so I was hoping someone can point me in the right direction
I just purchased a set of CCW SP550's in 19x10 front and 20x11 for the rear. I got a great price, but the previous owner did not keep the barrels cleaned so they are off being powder coated at this time. I was told the best sizes for these rims are 275/35/19 (26.6") and 305/30/20 (27.2"). I want the Pilot Super Sports, but the 305's have been pushed back until September of this year per the rep at Michelin I spoke with.
I had also looked at the PSS in a 275/30/19 (25.6") and the 325/25/20 (26.3"). I was told by John at CCW that the rears would balloon the side wall out as an 11" rim is a little narrow for the 325/25.
I have used Toyo R888's before and like them, but the closest set up for me they have is a 295/30/19 (26") and 315/30/20 (27.6"). Has anyone ran a 295 on the front of a standard C6, and if so, did you have any issues? Pictures are welcome and encouraged!!!
Thank you"
Old 02-24-2013, 08:05 PM
jw1
jw1's Avatar
I have 295/30/18s Toyo R888s on 18x10.5 TSWs on the front of 2005 as my daily tires.
I had some rubbing issues with wheel weights that were on the inner portion of the wheels that needed to be removed. Other than that, I think they fit fine, other than my car is a little lower than I would like for the given fender/tire gap. With the 19" wheels you should be fine as long as you have the correct offset.
Old 02-24-2013, 08:30 PM
TLTONEY
TLTONEY's Avatar
Do you have any pics of your set up?
Old 02-25-2013, 01:25 AM
michaelinmech
Support Corvetteforum!
michaelinmech's Avatar
A 295/30-19 tire on the front of a standard C6 seems huge to me. I would think there would be rubbing issues, and that large size may negatively impact your handling balance? Just my thoughts . .
Old 02-25-2013, 02:00 AM
raspyc6
raspyc6's Avatar
too big...it is...noone corners on that
Old 10-22-2013, 04:03 PM
titopanama
titopanama's Avatar
even with the compound of the r888?
Old 10-22-2013, 04:04 PM
titopanama
titopanama's Avatar
"Hello,
Thank you"
im really interested in the same set up for a c6 z06, did you tried?
Old 10-22-2013, 06:45 PM
budgreen3564
budgreen3564's Avatar
My 2013 Z06 came with 285 30 19 Michelin Pilot ZP on the Cup wheel.
Old 10-22-2013, 07:27 PM
titopanama
titopanama's Avatar
so I believe 295/30 r19 might fit... and your tires are?
Old 10-22-2013, 07:56 PM
budgreen3564
Michelin Zero Pressure. Run flats.
Old 10-22-2013, 08:11 PM
titopanama
titopanama's Avatar
Sorry i mean, your tires size rear and front pls
Old 10-22-2013, 10:16 PM
budgreen3564
285 30 19 Front
335 25 20 Rear
Old 10-22-2013, 10:59 PM
titopanama
titopanama's Avatar
285 30 19 Front
335 25 20 Rear
Im going for the toyo r888, so only option i have is 295/30 r19 front and 315/30 r20 rear..
. Any thoughts about it? thanks
To Anyone running a 295/30/19 on the front?
Quick Reply: Anyone running a 295/30/19 on the front?
