I win most miles out of my OEM GS tires
I had one alignment done at around 3,000 miles. Otherwise they wore pretty evenly.
The new tires give a much smoother/quieter ride. They have a pretty wild looking tread pattern.[/QUOTE]
Did you use the specs supplied by Pfadt for your alignment? Or?
St. Jude Donor '10
I put on Michelin Pilot Super Sport PZ today on my '08 Z51. WOW! What a difference. And...they are less expensive than the Pilot Sport PS2 ZP.
Anyone needing tires, I highly recommend you giving these a look.
Bobby
Bobby
#33
10,800 on mine and they will not make it a far as the OP. I plan to get the Michelins too so I'm interested in comments about new products and run flat discussions.
#34
Op, I figured you were driving in reverse. J/K - good job on the mileage
My rears were just changed with 8300 miles.
#37
Wow I have 16,600 Miles on My original Goodyears. My Fronts are 5/32 and my rears are 4/32. Lets see if I can beat you.
#38
I spent some $$$ at Firestone and have alignment for life. I probably get the alignment done every month and a half or so and the wheels balanced every other time. Do you do something like that as well?
#39
I only had an alignment done at the 3,000 mile mark by the dealership. I did keep a close eye on tire pressure but other than that nothing special.
Something else is I never got a flat with these tires which I guess is a little unusual.
When I had my 2005 coupe I also got great mileage out of the stock tires (around 38,000 miles) but I must have gotten 4 or 5 flats over that time which required repair.
