Introducing DashLogic for C6 Corvette
Former Vendor
We are finally selling DashLogic for C6.
DashLogic is the most advanced way of displaying vehicle data to date. There is nothing to install, no programing, no changes to your vehicle in any way. Simply plug in the DashLogic device to your vehicles OBD-II port and DashLogic turns your factory dashboard display into a fully customizable gauge canvas. See all of the data your vehicle has to offer on your Driver Information Center or Head-Up Display. DashLogic doesn't stop there, you can also customize visual and audible alerts that you set to any condition for any vehicle value, fully customizable by you. Just in case your car doesn't have a sensor for a value you would like to watch, DashLogic also has two auxiliary inputs so you can add up to two aftermarket sensors to be viewed on your DIC or HUD as well as be used for alerts. The DashLogic alerts system is a very advanced tool, this is not your run of the mill type of simple alert that only watches one value. DashLogic will take into account several conditions for one alert, all of those conditions fully customizable by you. We have even included NPP exhaust controls! We'll be updating this thread with additional information.
http://www.palmerperformance.com/sto...products_id=76
We are happy to answer any questions you may have. Thank You
548chevelle (02-17-2016)
Former Vendor
Yes, we can get all of that. You can view boost in a straight absolute KPA off of the MAP, or you can tell it to convert it to PSI of boost. Past that, you can also set alerts for all of it. For example say if load is greater than 60% and AFR is greater than 12.0 and boost is over 3psi then set a warning on the display and chime the seat belt chime. You can set several alarms, and you can configure them to about any formula and condition that you can think of. It also has 3 profile positions, so you could set alarms for profile one meaning race tune, then click the switch to profile two and have several alarms for your street tune, or whatever you would like to do. We really took our time and tried to cover everything we could think of that would ever be wanted from this device.
I can get a real image of this stuff (well not boost because our Z51 doesn't have boost ), but here is our display for SEMA showing an example of exactly what you were asking for.
So how about from a WideBand 02? Which have you all confirmed working as of yet? This would be the perfect solution to avoid putting another gauge in my pillar...
Thanks!
Thanks!
Former Vendor
is it possible to download the software so that I can see the inputs and options available etc?
Here is another vid of one of our early BETA testers using DashLogic. It appears from the video he has set up DashLogic to show when his water/meth injection is active on the HUD (bottom right number), he is also showing IAT in *C.
Former Vendor
use the zoom on your camera phone and do it around dusk. (see video below) btw cool technology and great job hacking the BCM to give more info.
Can you record data and download to a laptop or is it just real time display?
Miller Time Wisconsin 🍺
Location: The only thing we have to beer is beer itself 🍺
Received 1,440 Likes
2018 C7 of Year Winner
2017 C7 of Year Finalist
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
WOW! If this aint the greatest thing since sliced NPP collars! Subscribed.
Have you guys tested this piece to make sure you can't inadvertently break the unit with your leg?
