Introducing DashLogic for C6 Corvette
#301
Received 1,194 Likes
St. Jude Donor '15
honestly any one with a 0-5V output would work. I picked up the one they had on their website.
Just so you know unlike a traditional wideband gauge there's an ever so slight delay on the reading on the DIC to the actual reads (maybe about 1/4 to 1/2 second). For me it's not the end of the world. If you want a real time reading you'll need an actual gauge. Something to keep in mind.
I went with the gen 4 PLX, w/4.9 sensor. I tried one from Innovate Motorsports before the PLX and had a lot of problems. PLX one has been going for about 6 months straight (nearly daily) without a single issue
#302
I need to monitor my SC (e-force) LS2 and after reading a lot I'm pretty decided to go dashlogic route.
Would you recommend single or double WB sensors?
Why?
I'm having the car custom tuned with HP tuners, is there any problem using Dashlogic after the tune is done?
Thanks! any input is welcome
Why?
#303
St. Jude Donor '15
What do you want to monitor other than AFR?
#304
#305
St. Jude Donor '15
The monitoring 1 bank vs. both with a wideband question is really up to you. Most people just monitor one. In a perfect world they would be the same, but usually bank 1 runs a little leaner, so that's the one I log (driver side)
Depending on what MAP sensor is used you can log boost with dash logic as well.
max_moto (01-27-2016)
#306
Anyone having issues with Dashlogic losing communication after driving for about an hour? The NPP option continues to work, but the DIC display defaults back to oem. I tried pressing reset on the dash and nothing. Pressing the door lock will change the page 1-8, but no data. For it to work again, I have to unplug/plug back in. I have v1.21 firmware.
#307
Mike's LS3 (02-21-2016)
#308
Received 2,310 Likes
C4 of Year Winner (performance mods) 2019
Have the same issue with 1.21. Contacted support and their only suggestion was to reflash with the same image, which didn't help. I've found that you can pull the DashLogic and replug it while driving and it will reset to normal operation, but I plan on going back as well.
#309
Message to Palmer Performance Engineering:
Please fix bug with v1.21 on Dashlogic, device loses communication after driving about an 45 min.
Thank You!
Edit: I went on their forum and others have the same issue. No response yet on a November 2015, post.
Update: Big Thanks to Sevinn! After a 2 hour continuous drive no loss of communication with v1.18. Evan 70 if you want a copy of v1.18 PM you email.
Thank You!
#310
St. Jude Donor '15
Responsiveness isn't their strong suit
I haven't had the issue but it might just be sheer coincidence
#311
Thank You!
Thank You!
If anyone else needs it, I've uploaded it to my google drive:
https://drive.google.com/folderview?...drive_web#list
Seadawg (02-22-2016)
#314
I remember reading on your site that this unit can open and close the exhaust with the mirror control switch. Is there a way to have it automatically control the exhaust at user defined RPM points? The old exhaust commander elite could do this and I loved it.
Also, can this unit replicate some of the function of a window valet? Can it add auto-up to my windows?
#315
St. Jude Donor '15
No and no
Z2Z (04-10-2016)
#317
St. Jude Donor '15
Yes
#318
Quick question,
After a quarter mile run or 0-60 run etc -
What is the quickest or easiest way to reset the data to do another run?
How do you reset it?
Is it just a waiting game or do you use the reset button?
Thanks, Matt
Thanks, Matt
#320
