Stock stereo sounds better than kenwood???
Have an '09 with non-Bose set-up. Previous owner switched out front and rear speakers with Polk Audio. I wanted nav so I bought a used Kenwood 7100 head unit. Double D set me up with with the harness and sw controls. Did a comparison of sound between the 2 head units and the stock unit sounds much better than the Kenwood. Couldn't figure out why so I took it to Cartoys to check out my setup. Everything checked out. They too noticed the sound difference. I asked them "shouldn't the Kenwood unit sound better than a stock unit". They said definitely. They then went on to tell me that the Kenwood unit was functioning properly and was simply "clipping out". Think this means hitting max sound....when you start hearing distortion??? We then went into the showroom and listened to some new units. Every unit didn't sound as good as my stock unit? Opinions welcome!!
Btw....would've posted in the audio section but think this section would get more visibility.
Did you add an amp and sub? You need those to go with the aftermarket speakers and Kenwood head unit.
I have a Kenwood DNX9140, Kenwood Excelon KFC-XW1000F 10-Inch sub, Kenwood Excelon XR-5S amp, and Focal K2 Power 165KR speakers up front.
I also added sound and heat insulation and my systems sound a lot better than the stock (non Bose) radio in my 2010 coupe.
I would have guessed that Dennis would have suggested an amp and sub.
I would just start with an inexpensive, 4-channel amp and then listen to your new sound, especially with all the tonal controls in the Kenwood. If you decide you still want NAV and a sub then sure you'll spend a lot more.
There are quite a few that are small, lightweight but really put out some power. Just as an example, this Rockford Fosgate fits in the palm of your hand: (no affiliation). http://www.ebay.com/itm/ROCKFORD-FOSGATE-PBR300X4-PUNCH-4-CHANNEL-300W-RMS-CLASS-D-NEW-WARRANTY-/230987259292?pt=Car_Amplifiers&hash=item35c7e9dd9c
No matter what the car, I've never heard aftermarket speakers sound as good powered from the HU as they do amplified. Your stock radio probably sounded good with your stock speakers because they're matched together insofar as low power handling.
I would just start with an inexpensive, 4-channel amp and then listen to your new sound, especially with all the tonal controls in the Kenwood. If you decide you still want NAV, then sure you'll spend a lot more.
I am pretty sure that the OEM speakers in the doors are powered sub/mid-range speakers. If you switch them out to aftermarket speakers, you need to add an amp to power them and a sub for the low end.
Even a good aftermarket head unit would suck at powering aftermarket speakers, even with the 50Wx4 sticker on it (really more like 10Wx4). That's why they have preamp outs on the back.
If that's the case, then shouldn't Kenwood, Pioneer, etc put a disclaimer on their units that says something like "The stereo you've just purchased will sound like crapp unless you shell out a few hundred more for one of amps". Or "The stereo you've just purchased will not sound as good as the Ac/Delco unit that doesnt specialize in making car stereo units that originally came in your car".
If it was just a head unit swap then that might be OK, BUT the OP said that the previous owner had swapped out the speakers as well.
Thanks for the info. I have the stock stereo (non Bose) and was trying to decide what to do to make it sound better. I think I'll start with new speakers. That might be all I need.
I spent some time in the Audio section before I upgraded my audio system and most of the advice that I received was that to just swap out the head unit by itself would not be worth it.
A combo of an aftermarket head unit, along with speakers, amp, and sub is the best way to get improved sound.
The OEM door speakers are designed to work with the OEM head unit.
Spend some time in the Audio section and get some insight from some of the experts there.
On a side note....wish Dennis was closer. From what I hear, he'd make my stereo sound like I was front row at a Van Halen concert.
I'd think the quality of your speakers would affect the sound more. I upgraded the front & rear speakers and disconnected the center dash speaker. The sound is much better now.
