Slight Hesitation / Black Soot
Old 10-02-2013, 09:48 AM
Eppieguy
Eppieguy's Avatar
Default Slight Hesitation / Black Soot
2009 Base M6 w/ 14,800 on the clock. Not a daily driver but when I drive it (usually once a week) I don't baby it. Lately when i'm lugging it I've noticed a slight hesistation in it but goes away real quick when it give it a little more throttle. I wasn't 100% sure it was a hesitation but lately I've noticed after putting 200 ish miles on it that my center exhaust pipes are real black with soot. I've never seen them get that dirty that quick before. I have M2W installed that why it's on the center pipes I believe. I poured a container of Seafoam in to the fuel in the last week of Auguest and drove it to the tank was almost empty. I use Exxon Premimum fuel only in the car. Any ideas?
Thanks!
Old 10-02-2013, 10:34 AM
Seadawg
Seadawg's Avatar
It could be a dirty air filter or MAF sensor, or it could be normal. Do you have the stock or aftermarket air intake system?
If aftermarket and it is an oiled air filter, it can contaminate the sensor.
The center pipes do get "black" with normal driving, if left "open" with the MTW switch.
IF the car is in "good tuning" conditionmeaning no current issues, an aftermarket tune will greatly eliminate the pipe buildup.
These cars naturally run a little rich it seems.
Old 10-02-2013, 11:29 AM
Eppieguy
Eppieguy's Avatar
No CAI, OEM Filter, never looked at it to be honest. Stock tune as well. The pipes have never gotten this direty this quickly, only in the last few weeks. Last night I got on it in competition mode and it gave me poof of black carbon out the pipes, it's never done that before either.
Old 10-02-2013, 11:49 AM
John Harry
John Harry's Avatar
St. Jude Donor '10-'11-'12-'13-'14
Loose spark plug wire? Just a guess.
Old 10-02-2013, 12:03 PM
jack5hd
jack5hd's Avatar
How often do you lug the motor?.i never let tach below 2grand...........you might need an italian tuneup...........:d
Old 10-02-2013, 12:06 PM
jack5hd
jack5hd's Avatar
Your motor might have a lot of carbon build up if you lug it all time.seafoam doing it's job..go to shell gas and fill it up with 93 and go run car hard...........
Old 10-02-2013, 12:51 PM
Eppieguy
Eppieguy's Avatar
I dont lug it often and everytime I do drive it I do drive it hard at least once to blow it all out. This has started within the last month or so, something has changed, just not sure what it could be.
Old 10-02-2013, 06:27 PM
RocketDawg
RocketDawg's Avatar
CI 6-7-8 Veteran
St. Jude Donor '09
I also have an '09 but it's an A6 and I get a hesitation too; it's always after I've coasted (say slowing down for a red light that turns green before I stop) and then touch the gas to speed up "normally". The hesitation doesn't last long, but it's there. I've had dealers check it 4 times and an independent shop check it once and they say they can find nothing wrong.
I don't have any more than the normal amount of soot on the tips though, and I don't get smoke when I accelerate hard.
Old 10-03-2013, 07:15 AM
Seadawg
Seadawg's Avatar
Have you checked it for any codes?
Old 10-03-2013, 07:26 PM
Eppieguy
Eppieguy's Avatar
No, I have not, it's not showing any lights nor has it in the past but I will check since I have a scanner which is collecting dust anyway.
Old 10-04-2013, 09:51 AM
Chevy Cust Svc
Chevy Cust Svc's Avatar
Hi Eppie,
Use the dusty code reader! Let us know what codes, if any come up. If you do decide to have it checked out, let me know. I am not technical but I can help in other ways. Have a great weekend and hopefully you have her up and running well by next week,
Kelly J.
Chevrolet Customer Care
To Slight Hesitation / Black Soot
Quick Reply: Slight Hesitation / Black Soot
