Can I clear this curb ? !
I have a curb like this, I use a 2x12. I cut them into 3' sections and it works great. The problem you will run in to with the 2x4 is that it will flip the other end up when you roll upon it and hit he under carriage of your car pretty hard. Be careful!
Your spliter will hit before the tires hit the 2by4 use an 2by6 cut he edges at 45 degree angel for better fit.
z51vett
Doug
z51vett
Doug
Backing in has worked for me as well.
If you are really concerned about this, why not take the splitter off and either leave it off or put a standard OEM splitter on it for the trip up to Denver. Once you get it there, you can experiment and find a routine that will work for you.
I would say no not without a bit of slight scraping of the lower air damn.
