Low Beam Headlight T10 Torx Screw
Old 09-16-2013, 09:12 PM
slickstick
slickstick's Avatar
Default Low Beam Headlight T10 Torx Screw
I managed to drop one of these trying to install new bulbs. The dealer says they can't find one and don't have the dimensions... Very helpful. Does anybody know where to order this or at least the dimensions so I can scour the internet? I've got a bulb held on by one screw, waiting to swap in my 6000Ks until I find one in case I might lose another
Old 09-16-2013, 09:24 PM
Ozarkwoods
Ozarkwoods's Avatar
I would contact member RLSebring he might have some spare parts for headlight buckets
Old 09-16-2013, 09:31 PM
RocketDawg
RocketDawg's Avatar
CI 6-7-8 Veteran
St. Jude Donor '09
Couldn't you take the remaining screw to the dealer or hardware store and see if they can match it? Or measure it yourself (length, diameter, thread pitch) and then check the internet?
Might want to pick up some spares when and if you find a match. And use a magnetic screwdriver.
Old 09-16-2013, 09:37 PM
slickstick
slickstick's Avatar
Home depot no luck... Magnetic torx wrench definitely would have been clutch in this situation.
Old 09-16-2013, 10:24 PM
JoesC5
JoesC5's Avatar
Received 1,700 Likes on 1,214 Posts
I did the same. Had to go to a hardware store and pick up a 4mm X 10mm length with a Phillips head. Thread pitch wasn't the same, so it cut new threads in the plastic as I screwed the bugger in. I glued it(using contact cement) to the tip of my screw driver so I wouldn't also drop it into the headlight housing. After insertion, the contact cement breaks loose easily.
Old 09-27-2013, 04:53 PM
slickstick
slickstick's Avatar
Thanks for the lead... Robert said he has some extras and will send me some out! Didn't even ask for anything else in return. What a class act.
Old 02-07-2016, 12:49 PM
markdburton
2nd Gear
markdburton's Avatar
I wanted to let people know in the future that #4 x 3/8 screw will work as well. It was easier for me to find than a metric size. The screw went in easily and did not feel like it put new threads in the plastic.
The following 2 users liked this post by markdburton:
Grimlock13 (02-08-2016), The Clevite Kid (12-16-2023)
To Low Beam Headlight T10 Torx Screw
Quick Reply: Low Beam Headlight T10 Torx Screw
