Factory Gumby's vs. reproduction wheels
Cruising
I recently hit a pothole in my '09 and bent my lf and lr wheels. My question is: what is the difference (besides price) between the oem wheels and the factory reproduction wheels?
I went to the dealer and they want close to $3000 for the two wheels.
The Gumbys are forged wheels, which is an expensive process but yields a very strong, but lightweight wheel. Most wheels are cast, which is not as strong and so requires more material and thus is heavier.
How bad are they bent? Bending a forged wheel is kinda hard, I'd think it'd have to be a HUGE pothole with high speed to bend a forged wheel. You may be able to just have the wheel fixed, I've heard of places that can reshape the barrel and take the bend out of the barrel of the wheel.
I'd be more inclined to buy a used set of OEM Gumbys if it was me. But honestly, I'd think the alignment would get knocked out of spec before the wheels were bent.
Cruising
To clarify, it wasn't actually a pothole. The highway was milled about 4" down. The construction company used temp patch at a concrete bridge and the patch didn't last. Needless to say, 70 mph into that lip bent the wheels. I haven't had the alignment checked yet.
I'd prefer to pick up some nice used oem wheels. I appreciate the tip on getting them straightened. Ill look into that.
Received 2,478 Likes
St. Jude Donor '15
"In honor of jpee"
Usually reproduction wheels are just appearance wise the same. They may use different quality materials, have slightly different design elements, and be made in totally different ways.
Regardless, I would not put repros on just the LF and LR; I'd either replace all four w. repros, or find two, new, original equipment gumbys for LF and LR.
I've heard from several sources, but can't verify from personal experience, that if you damage your car by hitting a pothole (or poor construction practices might be the same) in my state, the city/county/state is/are liable for damages.
You might also consider an insurance claim.
Cruising
Why don't you file a claim with the state and/or the construction company?
Insist on OEMs. That's what was ruined by something that was their (company or government) fault. If they give you a hard time, point out the differences in construction and the attendant safety differences.
