OEM Mufflers- Are they side specific?
Race Car Tech
I have OEM mufflers, with the dual exhaust tips. The outlet of the mufflers are not centered, and are more on the outside section.
This setup make the tips pretty far apart from each other.
I would like to get the tips closer together, and I was thinking that if I swapped the mufflers to opposite sides, RH to LH etc, then the tips would be pretty close, or at least closer to each other because the outlets would be on the inside section.
Is it possible to do the swap, or will the exhaust pipes need to be bent to prevent any hitting. Will the hangars need to be repositioned?
Thanks for the responses.
Race Car Tech
They're supposed to look like that on the C6. Do you want to have 4 equally spaced tips like the C7 has?
Not sure if you could flip the mufflers over or not, but I don't really see why not offhand if that's the look you want.
Race Car Tech
I just don't care for the big gap between the tips, and I'm not a big fan of the exhaust plate to put in between the tips.
I'm thinking it's not easily done, or lot's of people would of tried it by now.
I'm praying that someone on this forum has attempted this before.
The mufflers are side specific. The pic below is of NPP mufflers...but it gives you an idea of what would happen if you just tried to swap them from side to side...
Race Car Tech
I'm not trying to rotate them, I'm trying to move the left muffler to the right side, and the left muffler to the right side.
That way, the tips will be close together.
The only issue may be the exhaust pipes to the muffler inlets.
Race Car Tech
