Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-24-2013, 08:12 PM   #1
Red08
CF Senior Member
Red08's Avatar
Default Do you own a torque wrench?
I am thinking of getting one, but not sure how much I would use it.
Red08 is offline   Reply With Quote
Old 08-24-2013, 08:16 PM   #2
FAUEE
CF Senior Member
FAUEE's Avatar
Yep. The ones at Harbor Freight are cheap, and work well enough. Good for your typical easy to do stuff (spark plugs, wheels, etc.)
If you think you're going to use them a lot, a nice Matco or Snap-On is always a good choice, but for just occasional use, the HF ones work and are $20 or less.
FAUEE is offline   Reply With Quote
Old 08-24-2013, 08:16 PM   #3
RocketDawg
CF Senior Member
CI 6-7-8 Veteran
St. Jude Donor '09
Send a message via Yahoo to RocketDawg
No, don't have one. Thought about it too but figured I'd never use it.
About the only thing I'd use if for is for tightening lug nuts to spec, and I rarely remove the wheels myself. If I do, I just snug them up. I don't really do any other mechanical work on the car.
RocketDawg is offline   Reply With Quote
Old 08-24-2013, 08:33 PM   #4
noz34me
CF Senior Member
noz34me's Avatar
Yep; got 3 of 'em. Don't use them very often, but there's no substitute when you need to torque a nut or bolt to a certain point- - and stop.
noz34me is offline   Reply With Quote
Old 08-24-2013, 08:34 PM   #5
B y r o n
CF Senior Member
Support Corvetteforum!
B y r o n's Avatar
If you're a tool guy than you probably own more than one torque wrench, I do anyway. Depending on what you're working on will determine what size and type you buy. By the way, if you watch the HF ads you can find their wrenches for $10 on sale.
Beam type are usually less expensive, followed by clicker type and then digital which seem to be the latest. If you work with small things requiring torqued screws/bolt or nuts 1/4" driver units are readily available. If you like turning wrenches you'll collect 1/4", 3/8" and 1/2" torque wrenches. Maybe even some larger drives if you work on large trucks.
B y r o n is offline   Reply With Quote
Old 08-24-2013, 08:35 PM   #6
MARSC6
CF Senior Member
MARSC6's Avatar
They are nice to have. Just remember to always turn the setting back to 0 before storage.
MARSC6 is offline   Reply With Quote
Old 08-24-2013, 08:35 PM   #7
black.z51.c6
CF Senior Member
black.z51.c6's Avatar
I have the 1/2" and 3/8" drives from Harbor Freight. Works good enough, definitely not Snap-On though
black.z51.c6 is offline   Reply With Quote
Old 08-24-2013, 08:39 PM   #8
JW@JWMotoring.com
Supporting Vendor
St. Jude Donor '09-'10-'11-'12-'13
JW@JWMotoring.com's Avatar
jmotoring jwmotoring C5ish
I have 2. Always best to get the correct torque spec on everything.
JW@JWMotoring.com is offline   Reply With Quote
Old 08-24-2013, 08:43 PM   #9
Kadorja
CF Senior Member
Kadorja's Avatar
Cheap and they work well enough. I think I have 4 total. Honestly there's a lot of nuts and bolts that need to be torqued that many people don't. Some are ok not to torque but others I wouldn't go without torquing it.
Last time I had to use mine was on my Harley when I changed the front wheel and swapped the rotors. Definitely would not of done that without a torque wrench.
Kadorja is offline   Reply With Quote
Old 08-24-2013, 08:46 PM   #10
SmokinZ51
CF Senior Member
SmokinZ51's Avatar
I have two also. Should have bought them years ago. I use them much more than I thought I would especially when rotating tires.
I got mine at Sears when they were running a half off special. Think I paid around $40 each for them.
SmokinZ51 is offline   Reply With Quote
Old 08-24-2013, 08:49 PM   #11
Jeff-Ford
CF Senior Member
Jeff-Ford's Avatar
I have one. Its rarely used, but when I need one I have it.
Jeff-Ford is offline   Reply With Quote
Old 08-24-2013, 08:52 PM   #12
rcallen484
CF Senior Member
rcallen484's Avatar
Someone here once said he just tightened stuff until he stripped the threads and then gave it an extra 1/4 turn. I have used that method ever since.
rcallen484 is offline   Reply With Quote
Old 08-24-2013, 09:06 PM   #13
Rich Mickol
CF Senior Member
St. Jude Donor '13-'14
Rich Mickol's Avatar
Craftsman 1/2 inch.
Rich Mickol is offline   Reply With Quote
Old 08-24-2013, 09:21 PM   #14
Tide Will Roll!
CF Senior Member
Tide Will Roll!'s Avatar
Vendor here has a great deal on digital 1/2, i will find it later for you...after the race.....and the Ocoee trip....
Tide Will Roll! is offline   Reply With Quote
Old 08-24-2013, 09:21 PM   #15
JWingo
CF Senior Member
JWingo's Avatar
Craftsman 1/2 inch drive.
Blackhawk 3/8 with memory.
Matco 1/2 inch drive.
A must have in any toolbox.
JWingo is offline   Reply With Quote
Old 08-24-2013, 09:30 PM   #16
1bdvet
CF Senior Member
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
1bdvet's Avatar
Have fun, comes in handy torque the wheels evenly, 1/2 drive.
1bdvet is offline   Reply With Quote
Old 08-24-2013, 10:39 PM   #17
iclick
CF Senior Member
iclick's Avatar
I've had two HF torque wrenches for at least 10 years--"-drive ft-lb and "-drive in-lb. Several years ago I tested these along with two others that I had, a 40-YO Torsen torsion-bar (non-clicker) and a $350 Snap-On, and the HF wrenches out-performed even the Snap-On by a long shot. When I approached Snap-On about that they offered to have mine adjusted for a $40, about double what the HF wrenches cost. I sold the Snap-On instead. In all fairness, the scale on the Snap-On was easier to read and it had a higher-quality finish, but it should.
What's more, the HF wrenches have a lifetime warranty. If it ever fails just return it for a replacement, but keep your receipt. I know of no other torque wrenches with that kind of warranty.
iclick is offline   Reply With Quote
Old 08-24-2013, 10:40 PM   #18
Tom45
CF Senior Member
Tom45's Avatar
Quote:
I have the same drives from Harbor Freight. They were $10 each.
Tom45 is offline   Reply With Quote
Old 08-24-2013, 10:45 PM   #19
Jim2003
CF Senior Member
Jim2003's Avatar
Jim JVN2003
Yes a sears craftsman. Use it for checking torque on wheel nuts when I rotate tires. With 4 married kids that I do things on their cars, I need a lot of tools.
Jim2003 is offline   Reply With Quote
Old 08-24-2013, 10:51 PM   #20
peter pan
Life Time NCM #2196
peter pan's Avatar
Got one at Sears 20 years ago and replaced for free this year
peter pan is offline   Reply With Quote
Reload this Page Do you own a torque wrench?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
