Posting Pics
Posting Pics
I know! I've read every FAQ, seen all the helping posts by everyone here(I think). But for the life of me I cannot post a pic from my photobucket page to a thread. I am no a rocket scientist but I can tie my shoes. I just can't seem to figure out the part where you copy the img and post it. I've tried to copy the img but all that shows up is a ton the letters inside the img bookends. Any help is great appreciated. Any abuse or ribbing is expected.
Moderator
Received 3,588 Likes
Went to Photobucket
Selected the image you desired
went to the box on the right side and selected the bottom option (IMG)
The box turned yellow and the word copied appeared briefly
you went to Corvette Forum and pasted the copy into your post.
If you did all that you should see a picture appear:
in between the [IMG] tags you should see the url of the photo.
You can select quote on this post and see the proper code for the picture I posted.
Hope this helps. If you did all this and the url is not appearing properly, you have a copy issue, I think.
JD
It took my two different times but it now works. The problem I had was this; when I copied my photo i would paste the url in addition to the http that was already present in the add a photo box. I just had to delete the http then paste. Thanks for the help.
