Thoughts on removing the rubber/plastic lip under nose?
Old 08-21-2013, 01:58 PM
Kevin_NYC
Kevin_NYC's Avatar
Default Thoughts on removing the rubber/plastic lip under nose?
My new driveway has a bump that will not clear the 2.5in clearance of the 3 piece front plastic lip guard. There is a 6-10 inch 45 degree incline and then flat driveway.
I can hear it scraping the lip and distorting it to the point it seperates from the plastic button holding it to other pieces. I have tried coming in at all angles.
What are my options?
-Remove entire plastic lip guard
-Back in?
-do they make a higher lip guard?
Is it a DIY pop off or does dealer have to do it.
Old 08-21-2013, 02:01 PM
TLS_Addict
TLS_Addict's Avatar
You can take it off in about 3 minutes. Its not hard at all.
Mine hits too and it sounds just like what yours is doing.
I wouldnt take it off but I am debating on "trimming" it up slightly to see how it does. Be simple to take it off, mark it, cut it, and then smooth the cut surface so its not sharp.
Old 08-21-2013, 02:03 PM
wayback
wayback's Avatar
Received 2,887 Likes on 1,910 Posts
Pretty easy to remove. I have replaced mine after it was destroyed be a road gator.
Mine scrapes also....has also come loose from the plastic pins holding the 3 parts together. I just live with it.
Could replace it again, but it would end up the same so why spend the money. No one can see it anyway.
carpe dm
carpe dm's Avatar
I have the same problem. It is a bolt on piece, and easily removed. I don't think it really has any value other than appearance. I would like to put a "splitter" on mine, but that would scrape just as badly....
Old 08-21-2013, 02:05 PM
wayback
wayback's Avatar
It is for high speed runs....keeps the front from lifting.
Old 08-21-2013, 02:17 PM
4SUMERZ
Race Car Tech
Support Corvetteforum!
4SUMERZ's Avatar
Received 2,320 Likes on 1,664 Posts
I trimmed about an inch off mine as I also have an inclined driveway.
I still have to come in at an angle, but it doesn't scrape anymore.
Old 08-21-2013, 02:28 PM
Turbo6TA
Turbo6TA's Avatar
Received 3,087 Likes on 2,078 Posts
2021 C6 of the Year Finalist - Modified
I don't think that flimsy 3-piece rubber air dam is going to keep anything from "lifting".
I believe it is there to help direct air up into the radiator, and is needed for cooling.
If it scrapes all the time, I guess you could shave maybe in inch off it so it would not set so low. Removing it is a bad idea.
Old 08-21-2013, 02:35 PM
1bdvet
1bdvet's Avatar
Received 4,504 Likes on 3,589 Posts
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Mine scrapes for the last several years, haven't seen any damage that I feel I need to remove it.
Old 08-21-2013, 02:47 PM
SilverScorp
SilverScorp's Avatar
I dont think so. I thought it directed air up across the radiator to help keep it cool.
Old 08-21-2013, 02:50 PM
Rich Mickol
Rich Mickol's Avatar
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
Mine also scrapes. So does my splitter. I went to Home Depot and bought 20"x20" rubber patio blocks. About 6 bucks apiece.
I back down until I hear it scrape. Pull forward and put the blocks behind the front wheels to build it up. I then back out slowly.
I only do this because of the splitter scraping not the air dam. If it were just the air dam I could live with it.
Old 08-21-2013, 02:51 PM
wayback
wayback's Avatar
It does both I think. Creates neg pressure under nose which helps direct airflow thru rad. Neg pressure also helps downforce.
Old 08-21-2013, 02:56 PM
Steve_R
Steve_R's Avatar
Received 3,289 Likes on 1,399 Posts
St. Jude Donor '12-'13-'14-'15-'16-'17
It has nothing to do with downforce. It is important for cooling. Do not remove it. It's a wear item. It scrapes. It's cheap and easy to replace if it needs it. Removing or trimming it is a bad idea. Given all of that I don't understand the obsession some have with it rubbing and the lengths people will go to to stop it from rubbing. It doesn't hurt anything then it rubs.
Old 08-21-2013, 02:59 PM
truckplay
truckplay's Avatar
i got into a huge discussion over those 3 rubber pieces about a month ago. some claim that they create lift a speed, i don't believe it since they don't on my coupe (i took them off & tried it) they are there to direct air into the radiator.
you can trim them if you want or just SLOWLY BACK into your driveway. they are rubber and will fold and yes RUB will will not get damaged.
on wide body cars the lower air dam does get damaged especially the CF piece & that is expenssive. some have used planks of wood as a ramp if the transition is too great.
speedraider
speedraider's Avatar
remove to 2 sides and leave the middle section
Old 08-21-2013, 03:00 PM
TLS_Addict
TLS_Addict's Avatar
It draws attention.
Old 08-21-2013, 03:05 PM
Steve_R
Steve_R's Avatar
Originally Posted by TLS_Addict
It draws attention.
It's a Vette. It draws attention sitting in a parking lot. If someone doesn't want any attention, they should be driving a white Camry, not a Vette.
Old 08-21-2013, 03:07 PM
VET4LES
VET4LES's Avatar
Mine's been rubbing for over eight years (twice a day). It's made to rub. If it ever gets to the point of looking bad I'll replace it.
To Thoughts on removing the rubber/plastic lip under nose?
Old 08-21-2013, 03:47 PM
Jitsu
Jitsu's Avatar
This is what I did. When I bought the car one of the side pieces was damaged so I removed it along with the other side with the intent of replacing. I left the middle piece in place since it does direct airflow up into the radiator. I've not had any issues and my coolant/engine temps have remained the same. I've been driving it with the side pieces removed for a few months no with no problems but will eventually install new pieces.
Old 08-21-2013, 03:51 PM
IrishSpuds
IrishSpuds's Avatar
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
If you dont want to remove, try googling ramp systems and you may find something that works and does not look hideous. My $1.02 (inflation adjusted)
Old 08-21-2013, 03:57 PM
Binh360
Binh360's Avatar
Took mine off, been over two years now and my car is fine. Couldn't stand the scraping. Sometime embarrassing just like the brake squeal.
Quick Reply: Thoughts on removing the rubber/plastic lip under nose?
