Cleaning My Exhaust Tips
Old 08-17-2013, 06:22 PM
SHM
SHM's Avatar
Default Cleaning My Exhaust Tips
I noticed my inside exhaust pipe outlets were getting very black on my C6Z. So the last time I washed 'er, I used carb cleaner and some Easy Off oven cleaner on the inside of the exhaust pipe tips. I sprayed in a combo of both, not a lot, just enough to coat, then washed the rest of the 'Vette to give the cleaners time to soak in.
After I washed the rest of the car, I rinsed out the pipes with the hose and used a tool I also use for the inside of my rims. It's from Griot's Garage and it's a kind of polyester scrubbing tool. I used this on the inside of the pipes. The result was great. The pipes were as clean as they were when new. This was after almost 10K miles of use.
Jus' thought I'd pass this along....
Old 08-17-2013, 06:23 PM
dvilin
dvilin's Avatar
Received 7,922 Likes on 4,808 Posts
Thanks for the tip, pictures would be appreciated as well.
Old 08-17-2013, 07:39 PM
SHM
SHM's Avatar
My bad...I should've had my camera out. But, I didn't know how it was going to go. I've put on some mileage since I did this, so the pipes have probably darkened. Next time I'll do before and after picts. But, the method does work well. I was pretty surprised at how good the results were.
Old 08-17-2013, 08:37 PM
C6Whatever
C6Whatever's Avatar
Nice tip thanks for sharing.
Lisa
Old 08-17-2013, 08:53 PM
michaelinmech
Support Corvetteforum!
michaelinmech's Avatar
You don't clean and polish them monthly ???
Old 08-17-2013, 09:08 PM
SHM
SHM's Avatar
I guess it's one of those areas I forget to do when I'm detailing.
Old 08-17-2013, 09:11 PM
WV Vette
WV Vette's Avatar
Get you a Mothers Powerball and some of their metal polish. Use your cordless drill and within 5 minutes they loo good as new,
Old 08-17-2013, 09:12 PM
SHM
SHM's Avatar
That sounds like a great way to do the stainless outside trim.
Old 08-17-2013, 09:18 PM
Kvothe
Kvothe's Avatar
You don't clean and polish them weekly???
Fixed it for you
Old 08-17-2013, 09:22 PM
michaelinmech
Originally Posted by SmokinZ51
Fixed it for you
^ Better
Old 08-17-2013, 09:30 PM
hotrodln
hotrodln's Avatar
SOS pad with dish soap good as new....good for chrome rims too. takes the corrosion off and leaves a nice shine
Old 08-17-2013, 09:33 PM
heli-vette
heli-vette's Avatar
I've been using the soft stainless steel wool " grill cleaning " . Either Orange hand degreaser soap or driveway cleaner . Normally its just an oil / fuel drizzle line on the bottom inside .
Old 08-17-2013, 09:40 PM
michaelinmech
^ SOS Pad on Chrome = a gazillion fine surface scratches if not extremely careful . . . .
Old 08-17-2013, 09:45 PM
hotrodln
hotrodln's Avatar
lotsa soap and they come out great. back in the 70's and 80's there was chrome all over the cars....my 62 caddy is loaded with it....sos has always worked on chrome . you have to be more carefull on stainless though...you can eat it up!
Old 08-17-2013, 10:00 PM
Kvothe
Kvothe's Avatar
learned this the hard way when I first bought the car and the tips weren't as good as I wanted them.
I use some stainless steel wipes you can use on our fridge. I wipe them off once a week or so. That way they never get so bad that they are a chore to get clean again.
Old 08-17-2013, 10:52 PM
68sixspeed
68sixspeed's Avatar
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
You guys clean 'inside' your exhaust?? Wow, I barely found time to clean the outside! I hope I don't lose corvette privileges for not cleaning inside my tips...
Old 08-17-2013, 11:12 PM
Steve_R
Steve_R's Avatar
Received 3,289 Likes on 1,399 Posts
St. Jude Donor '12-'13-'14-'15-'16-'17
If you lose yours I'll lose mine too because I'm thinking the same thing. Except for show cars people actually clean the inside of exhaust tips?
To Cleaning My Exhaust Tips
Old 08-17-2013, 11:29 PM
rwpatte
rwpatte's Avatar
Clean mine every time I wash car, 5 minute job with Mother's mag cleaner, and rag. Never let them get dirty enough to take much time to clean. Just part of keeping it looking sharp. Like polishing wheels, or cleaning wheel wells. Pride of ownership.
Old 08-18-2013, 12:19 AM
Glen1224
Glen1224's Avatar
Location: Lower Macungie Township ; Commonwealth of Pennsylvania
I already washed my car for this year. Well not the wheels; I'm starting to like the grey brake dust look on the chrome wheels. It's better than plastic dipping the wheels
The exhaust tips are not getting that nice grey patina on them like I'd like to have but they may get better with age
Personally ; I'd rather be out driving it than washing and polishing it
Old 08-18-2013, 12:54 AM
Blue Bandit
Blue Bandit's Avatar
On my Corsa Extreme Exhaust, I use, Simichrome, a drill, a long drill attachment with a sponge ball on the end - I wrap a cloth around the sponge & hold with a rubber band or tape. Works great.
Quick Reply: Cleaning My Exhaust Tips
