Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-07-2013, 03:14 PM   #1
TurkeySlugger
CF Senior Member
Default Nitto Invo vs. Pilot SS
which ones do you guys prefer. Ill be running 345/30/20 for the pilot ss and 345/25/20 for the Invo.
TurkeySlugger is offline   Reply With Quote
Old 08-07-2013, 03:42 PM   #2
LFZ
CF Senior Member
LFZ's Avatar
The Pilot SS in that size is way too tall....Invos will do the job, but suck for any kind of performance use.
LFZ is online now   Reply With Quote
Old 08-07-2013, 03:55 PM   #3
Turbo6TA
CF Senior Member
Turbo6TA's Avatar
BTW .... There actually called: Nitto Invo
Probably not as good for traction as the Michelin Pilot Super Sport, but the cost is a lot lower.
The Nitto Invo is still a very good value for the money, and there are many members here using them on there C6s
Turbo6TA is offline   Reply With Quote
Old 08-07-2013, 04:16 PM   #4
TurkeySlugger
CF Senior Member
Title fixed thanks. LFZ should i got with 25?
Old 08-07-2013, 04:38 PM   #5
speedraider
CF Senior Member
speedraider's Avatar
Quote:
really, my car has gone 10.90 on Invo's
speedraider is offline   Reply With Quote
Old 08-07-2013, 05:15 PM   #6
LFZ
CF Senior Member
LFZ's Avatar
Quote:
The only Michelin SS tire that would work in a 20" is the 325/25-20...then youd have to go down in size on the fronts to make it work. Still worth it over the Invos.
Quote:
Yea, but don't you have well over 600rwhp!!!
Old 08-07-2013, 05:17 PM   #7
TurkeySlugger
CF Senior Member
which do you prefer. i would like to run as wide as i can in the rear but i dont want it to look like im running drag radials
Old 08-07-2013, 05:33 PM   #8
FAUEE
CF Senior Member
FAUEE's Avatar
I had INVOs on a previous car. They don't last long, pick up a lot of stuff from the road, and are scary when its less than 60 degrees out.
That said, they're quiet for as aggressive of a tire as they are, have impressive grip in the rain, are reasonably priced, and grip pretty well. I don't know about 600rwhp well, but there's not much in a street-able tire that does well with that much power.
FAUEE is offline   Reply With Quote
Old 08-07-2013, 05:39 PM   #9
TurkeySlugger
CF Senior Member
its going on my daily and im only pushing 453. want something that i am going to have to replace in a month with good wet, dry, cold, hot road.
Old 08-07-2013, 05:48 PM   #10
FAUEE
CF Senior Member
FAUEE's Avatar
Michelin All Seasons
Old 08-07-2013, 06:02 PM   #11
THE MOUTH
CF Member
THE MOUTH's Avatar
INVOS!! For the money you can't go wrong IMO!!!
THE MOUTH is offline   Reply With Quote
Old 08-07-2013, 06:17 PM   #12
TurkeySlugger
CF Senior Member
i cant find anyone that sells the tires that large.
Old 08-07-2013, 08:30 PM   #13
peter pan
Life Time NCM #2196
Support Corvetteforum!
peter pan's Avatar
SS all the way
peter pan is offline   Reply With Quote
Old 08-07-2013, 09:40 PM   #14
gbranham
CF Member
gbranham's Avatar
Love my Invos! Orders of magnitude better than the stock Eagle F1 Supercrap tire.
gbranham is offline   Reply With Quote
Old 08-07-2013, 09:45 PM   #15
Garret
CF Senior Member
I believe in the Beer Fairy
Garret's Avatar
I'm going with the Continental ExtremeContact DW and I get them on tomorrow. I'm only getting fronts though as the backs will be OK for one more season. The Nitto's were my 2nd choice.
Garret is offline   Reply With Quote
Old 08-07-2013, 10:14 PM   #16
ILLUSHN
CF Senior Member
ILLUSHN's Avatar
I have a new set of Invo's going on tomorrow. My 2nd set.
ILLUSHN is offline   Reply With Quote
Old 08-07-2013, 10:31 PM   #17
TurkeySlugger
CF Senior Member
Im probably going with the SS but I have only been able to find them in the 345 that I want in 345/30 which I feel is to tall. Might have to go down to 325 so I can get 325/25.
Old 08-07-2013, 10:57 PM   #18
raspyc6
CF Senior Member
To the extent you can find and get a Pilot SS in the size you need you should do it. IT is simply the best tire out there. The problem one runs into was already mentioned by the fella above. If you are putting down 600 then NO street tire is going to give you dead hook capacity...none. Get DR's if you want a tire to street that has SOME tread pattern and rating OTW spinning will be early and often.
raspyc6 is offline   Reply With Quote
Old 08-07-2013, 11:00 PM   #19
phileaglesfan
CF Senior Member
phileaglesfan's Avatar
In stock GS/Z06 sizes the PSS are about $1400 a set. Mine have at least 7/32ds of tread with about 12k miles on them. Even if Nittos are $400 cheaper, over 30k miles or so the actual cost is practically nothing.
phileaglesfan is offline   Reply With Quote
Old 08-07-2013, 11:02 PM   #20
LFZ
CF Senior Member
LFZ's Avatar
Turkey....have you considered the Michelin PS2 ZP...standard OE tires on ZR1s, 427s, and certain Z06s. They are pricey, but they are also runflat and perform just as good as the PSS IMO. Then you can get them in the correct sizes for your widebody.
PS2 ZPs come in 285/30-19 and 335/25-20
Reload this Page Nito Nivo vs. Pilot SS
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
After Market Tires for GS sly4458 C6 Corvette General Discussion 14 03-25-2014 05:58 PM
Tire ? ROUTE 66 C7 Z06 Discussion 6 03-06-2014 02:10 PM
Who has the best price on Nito invos these days? BarneyZ C6 Z06 Discussion 2 02-21-2014 04:48 PM
Help !!! Michelin pilot ss 345 30 20 ??????? motolawson C6 Corvette General Discussion 4 07-19-2013 10:52 PM
Grand Sport tires thenorthwoods C6 Corvette General Discussion 13 12-14-2012 12:46 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
