Bunch of codes after sitting for more than a week
Just got back from vacation today and naturally i needed to run to the grocery store for steaks for supper and took the Vette
I backed out of garage and as I got ready to leave I noticed all kind of "service" codes on the DIC (anitlock brake service, Suspension and etc)
As I drove to the store I fooled with some of the buttons and got it to the mileage readout.
I even noticed the symbols lit up for traction control and ABS
I did notice the volt meter was little higher than normal
When I came back out from the store and started car again no codes or any symbols lit up
Am I correct to assume that over a week without starting was just a little weak battery issue
Since I have owned Vette it is driven at least every 2-3 days however this time it sat for 7-8 days
Received 3,289 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
If your battery can't sit for a week you don't need a battery tender, you need to figure out what the problem is.
I don't know how old your battery is, but this past week, I started my car after leaving it sitting for 19 days and it didn't even hesitate in the slightest. I'm in TX and we've had triple digit temps where I am the last few weeks. Hard for me to believe Vettes just eat up batteries at the rate posted on this forum.
To the OP: You have an '08 C6, right? 5 years is a decent life for a C6 battery.
So if you still have the original battery, start shopping for a new one NOW.
And it's not just Corvettes. Google "Porsche dead battery", you'll get the idea.
Yes, your near-new 2013 C6 should be able to sit for weeks without problems. But if that's your typical monthly usage, your battery won't live long.
Use a good battery maintainer (CTEK, Battery Tender, etc). You'll get longer battery life. And IMO the peace-of-mind is worth the minor inconvenience.
I think some people are reluctant to use a battery maintainer because they've never used one. Or maybe they just don't know the easy ways to connect 'em:
http://forums.corvetteforum.com/1584317211-post26.html
http://forums.corvetteforum.com/c6-c...r-hook-up.html
Lead acid batteries HATE to be discharged even slightly, and will
immediately start to sulphate.
Your car may start, but you have damaged your battery and shortened
it's life.
If my C6 is going to sit for over 3 days, I put the C-tec on.
The reason for the DIC display, ...low voltage.
C6 is not your family sedan, and isn't that why you bought it?
You most likely had a weak battery to begin with,you didn't mention how old it is. Replace the battery and use a battery tender. If the battery is newer have your charging system checked.
Car started fine, not a single problem or sound of dragging or weak battery at the start
Wife and I went on a short cruise for an hour last night and no other issues at all
I recently returned from a 10 day vacation, and decided to unplug the battery tender, which is usually always connected. The car started right up, no issues or warnings etc. Now that I am home again, I do connect the tender just to be sure.
I would suspect the battery as well.
When new,with only 300 miles my 2010 GS began setting all sorts of codes even with a battery tender connected when sitting.
Wasn't long and the battery lacked the power for the starter to roll the engine over.
Battery replacement resolved the issue................
Regards,
GSRANDY
Regards,
GSRANDY
C6 is like a race car, the computers draw .08 amps while sitting.
it's life.
it's life.
Of course it's exaggerated on forums, where people post their problems. But dead battery issues are real... in a healthy C6, infrequent use is the #1 culprit.
...the computers draw .08 amps while sitting.
it's life.
it's life.
Point taken.
I'm the type to rotate the use of my vehicles instead of letting the sit there. I forget that not everyone is like that though. I do have a tender that goes in the cigarette lighter which I'll be sure to use on my next driving hiatus.
I doubt I'll do the day to day thing though...that's a bit CDO...which is like OCD but with the letters arranged alphabetically...as they should be...
LOL. No, the C6 isn't "like a race car." It's a GM car that, electronically, is no different from most other GM cars and trucks you can buy, most of which don't have OCD owners that put battery tenders on them if they sit for more than a few days and their batteries do just fine.
My 12 didnt have any issues and either does my 13. They both sat for over a month at a time with no tender and never an issue. If its a new car I would say the battery wasnt properly prepped when new.
