key fob
Old 08-03-2013, 12:07 PM
richard emmanuel
richard emmanuel's Avatar
Default key fob
My key fob will not respond to driver door, but will respond to passenger door to unlock it. Whats the problem.
Old 08-03-2013, 02:14 PM
Cherokee Nation
Cherokee Nation's Avatar
Door switch.......
Old 08-03-2013, 02:17 PM
johnodrake
Moderator
Support Corvetteforum!
johnodrake's Avatar
Received 3,569 Likes on 1,614 Posts
Originally Posted by Cherokee Nation
Door switch.......
Most likely. Try cleaning it. just a couple of screws to take the pad out.
Old 08-03-2013, 02:24 PM
cclive
cclive's Avatar
Try leaving the drivers door unlocked, then put the fob far away and try opening the door. If it still doesn't open, then it has nothing to do with the fob and is probably the rubber pad switch...disassemble and clean, coat contacts with a light coating of WD-40. This problem is most common in areas of high humidity.
Old 08-03-2013, 04:26 PM
Cherokee Nation
Tell me about it!! You see where i live.Every yr i have to clean my.
Old 08-03-2013, 10:05 PM
CO Lightfoot
CO Lightfoot's Avatar
For $15, it's cheap & easy to get a new touchpad.
Do-It-Yourself CAUTION: After you disconnect the touchpad, DO NOT LET THE WIRING FALL BACK INTO THE DOOR!!!
Not the end of the world -- just more work to retrieve the wires.
You can secure 'em with a piece of string.
To key fob
Quick Reply: key fob
