How can you tell if its an LS2 or LS3
Cruising
How can you tell if its an LS2 or LS3..
Looking to buy a swap (LS3)
The one i may buy is missing the Fuel Rail covers and intake.
What should i look for to make sure its a LS3? Is there a serial # to look for?
http://www.researchmaniacs.com/VIN/VIN-Decoder.html
if you can find the vin # U is an LS2 W is an LS3
if the Mass is an assembly it's and Ls2 a card type an LS3
if the intake is off you can also tell Cathedral ports are LS2 Square ports are Ls3
Received 2,062 Likes
Also, if the engine is out, there's a "LS3" embossed on the rear of the block.
I stand corrected. I am used to seing the ports on my TF heads. I just checked my factory heads, it has been a long time since they have been on the engine.
http://www.onallcylinders.com/2017/1...y-an-ls-engine
Medical research has come a long way and the cure for this has been found. A young lady in her 20 s or if thats no good then Post - it notes all over the f..kin place . It must be noted that Post-its are much cheaper
Clif
Clif
Randy_in_MD (02-28-2018)
Just a FYI, but the Ls2 and LS3 blocks/engines are used in other cars than the vet, and do not make as much power as the vet LS2 and LS3 motors.
