Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-01-2013, 02:28 AM   #1
tjm9746
Junior Member
Default Mirror lights staying on
Has this happened to anyone and what might it be??
2 times now i have had to disconnect my battery to get to mirror lights to go out. I notice my radio and gauge lights get dull or bright from time to time also. any IDEA'S ????
tjm9746 is offline   Reply With Quote
Old 08-01-2013, 02:43 AM   #2
CaryBob
CF Senior Member
Support Corvetteforum!
CaryBob's Avatar
The owner's manual says they will go out after about 20 minutes, which has been true for me, if they are left in the "on" position. I inadvertently leave the driver's side light on all the time.
When you turn the car on, make sure both lights are off. If they are off while the car is running they should shut off after you exit the car. They are controlled by the pushbutton next to the light, and also by the dashboard light control to the left of the steering wheel. They should go on when you exit just like the dome light they are replacing, then go out.
The dashboard light control switch might be getting pushed in or turned, and that may be what is affecting the other light too. Check the owners manual for how that control works.
CaryBob is offline   Reply With Quote
Old 08-01-2013, 02:48 AM   #3
tjm9746
Junior Member
Thanks i also just read some old threads on it. It seems many have bumped the switch on the dash and i can understand, But I drove 40 miles trying the button on the dash and it just didnt want to go out I had to diconnect the batt. wait a few and reconnect.
Old 08-01-2013, 07:43 AM   #4
JimTN
Moderator
JimTN's Avatar
Quote:
And now you'll probably have to reset the window indexing.
The mirror lights won't go out as soon as you press that dash dimmer switch. It will just cause the mirror lights to go out normally after you get out of the car, close the door, and optionally lock the door or auto lock the door.
JimTN is offline   Reply With Quote
Reload this Page Mirror lights staying on
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Inside mirror info please The Rabbi C5 Tech 16 07-12-2014 08:50 PM
Need help! Rear view mirror lights stay on mundo C6 Corvette General Discussion 16 04-08-2014 01:47 AM
Mirror dimmer problem. Nosferatu C6 Corvette General Discussion 3 07-27-2013 09:56 PM
QUESTION - map light ? ZEE-OH-6 C6 Corvette General Discussion 13 07-15-2013 04:13 PM
Map Lights Stay on all the time LYLE C6 Tech/Performance 7 02-19-2013 10:47 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
