HELP! Stumped on 02 sensor code!
Hey Guys.
Well ive been getting the P0154 no activity in Bank 2 Sensor 1 code about a month ago and cant find out what is causing this.
Ive replaced, switched, re routed the 02 sensors and checked voltage, they are all good.
Also cleaned everything that can set them off and thats not it either.
The car has 14k miles on it and is an 05 C6 Lingelfelter tuned with a Cam, head work, headers and some other mild mods.
Now heres where im stumped. The last time this happened i was checking the computer behind the wheel so i took out the battery and when i reconected it the 02 sensors were all working just like they should. Drove it about 200 miles and BOOM the lights on again with no activity in Bank 2 Sensor 1 and all of the other sensors are all showing odd numbers (either low steady numbers or high steady numbers).
Anyone have any idea what would cause this? Bad ECM?
Id like to exhaust my options on the forums before i take it to get my walled raped at the local shop...
Thanks for any help guys.
-Matt
-Matt
Just a thought, you may want to clean the MAF. My ProCharged C6 began throwing some weird codes and a GM tech suggested spraying electronic cleaner on the MAF sensors and drying them with compressed air.
Worked fine and no codes since (4 weeks ago). It seems that aftermarket air cleaners that require occasional oiling is the culprit.
Good luck
Good luck
Thanks EuroRod.
Unfortunately I did that along with cleaning my air filter to try to eliminate everything but the computer....
I checked grounds, looked for bad wires, cant find a thing. Afterall it only has 14k miles on it.
What gets me confused is why it will work fine for a couple hundred miles, then go back once the computer learns the driving.
If not, find someone with an Android phone or tablet and grab Torque $5 and a $20 ELM327 bluetooh from Amazon.
You'll be able to graph bank 1 and bank 2 and compare the output.
Also who did your tune? Have you talked to them about this? I'd venture to guess there is something funny going on making it fail based on self tests. The OEM tune fluctuates rich/lean to keep the cats lit up. If your tune has smoothed that curve out, it could be causing this condition as well.
