Visor sticker removal
Old 07-30-2013, 06:18 PM
barduch
barduch's Avatar
Originally Posted by Don-Vette
Just cover them up!
I also bought these and they are a perfect match to the OEM fabric. Unless you were actively looking for them you would never notice them. Warning though, 10,000 years from now, when C6 corvettes finally realize some collector value, you will need to remove these to expose the original stickers. Should not be a problem except for "zombie" owners.
Old 07-30-2013, 07:17 PM
Ryan5508
Ryan5508's Avatar
My driver side had a corner that was already not stuck down. So it was an easy decision to peel it off. Not to mention it looks much better without it.
Not sure why the passenger side decided to be a complete pain. Like I said I tried goo gone. Tried scrubbing it with a toothbrush and scrapping at it with random stuff. Have not yet tried heating it up.
I debated covers but would rather just have nothing there unless its my only fix.
Old 07-30-2013, 11:24 PM
Vet
Vet's Avatar
Got a hold of a small roll of flat-black 3M adhesive vinyl sticker material, cut out rectangles the exact shape of the warning stickers, covered the warning stickers with the rectangles of flat-black 3M stuff... looks great, stickers still in place after 6 years of extreme heat and extreme cold. Good thing about this too, down the road I'm sure the 3M sticker material will peel off of the warning stickers (using a hair drier and a bit of care), revealing the original warning stickers if so desired. It was a bit of work to get the rectangles cut perfectly and then adhere them perfectly... probably easier to just get aftermarket stickers, as long as they are of high-quality sticker material like 3M or similar. Be sure that the warning stickers are perfectly clean before adhering cover-up stickers, perhaps quickly and gently give `em a once over with a bit of rubbing alcohol first.
Old 07-31-2013, 02:29 AM
DS Vettes
DS Vettes's Avatar
Originally Posted by Ryan5508
Pulled off the driver side warning sticker with nothing left behind. So I decided to take off the passenger side. It now looks pretty bad and cant get the white residue off. Any suggestions. Tried soaking it in goo gone. No luck[IMG][/IMG]
We have the ultimate solution for this problem. 100% leather sunvisors!
Old 07-31-2013, 02:44 AM
Ryan5508
Ryan5508's Avatar
don't tempt me
They look really nice!
Old 07-31-2013, 07:47 AM
J Vette
J Vette's Avatar
Originally Posted by Pittcorvette
I tried those and they didn't work. I do live in Texas and its HOT!! They fell off.
Thanks. I hadn't thought about the heat effect. I also thought about getting some printer sticker paper and make them myself. But that probably wouldn't work either.
Maybe the heavy duty double sided tape like they use to stick emblems on the headrest? Or just live with them!
Old 07-31-2013, 07:52 AM
J Vette
J Vette's Avatar
Originally Posted by ByByBMW
I'm sorry but I am throwing the BS flag on this post. I have traded in 5 different cars with the visor stickers removed and have NEVER had anyone question why they were gone. If this did happen to your friend, the dealer was just making up ways to reduce the trade in value on the car and your friend fell for it.
Oh, I can see yer a trouble maker. I bet you tear the tags off your mattress and pillows too
Old 07-31-2013, 08:15 AM
bucwheat
bucwheat's Avatar
I just covered mine up with the same material sticker,found by several vendors.
Old 07-31-2013, 09:01 AM
ufso
ufso's Avatar
I put on similar ones when they were first sold on this site by some vendor back in '05...they're still there and look great!
Old 07-31-2013, 09:43 AM
Globeman
Globeman's Avatar
Originally Posted by montereyredvette
Goo gone/goof off will do the job...the trick is to use it with a stiff brush..
I agree. I used Goo Gone and a brush. It took patience and lots of scrubbing but the ugly stickers are gone and you can't tell they were ever on there.
Old 07-31-2013, 10:43 AM
ByByBMW
Support Corvetteforum!
ByByBMW's Avatar
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Not always, depends on if they show or not.
Old 07-31-2013, 11:02 AM
michaelgerson
michaelgerson's Avatar
I installed plain black covers from forum vendor. Can't say they look great, because you really don't notice them. Which is the point. Lots of high heat and humidity n Houston with no effect on the stickers. Product works great and low cost. Glad I went that direction.
Old 07-31-2013, 11:38 AM
  #33
dndrsn
dndrsn's Avatar
Even the glue left behind looks better than the stickers.
Old 07-31-2013, 11:51 AM
  #34
Ryan5508
Ryan5508's Avatar
I have to agree with you on this!
Old 07-31-2013, 01:27 PM
  #35
bdanyluk
bdanyluk's Avatar
Black permanent marker. Just color the spot in. Works wonders!
Old 07-31-2013, 03:49 PM
  #36
SkyTopp
SkyTopp's Avatar
Mine came right off no goo.
Old 07-31-2013, 04:40 PM
  #37
EVRose
EVRose's Avatar
I'm gonna try that.
To Visor sticker removal
Old 07-31-2013, 05:02 PM
  #38
uwec86
uwec86's Avatar
Just cover them up!
These look great on my car!
Old 07-31-2013, 05:28 PM
  #39
C6Whatever
C6Whatever's Avatar
Do theses come with the mirrors ?
Old 07-31-2013, 05:45 PM
  #40
LDB
LDB's Avatar
Received 1,073 Likes on 434 Posts
I’ve used black iron-on patches from Hancock’s fabric stores on three Vettes and a CTSV. The match isn’t absolutely perfect, but it’s good enough so that I don’t notice them. They are super cheap, easy to find at any Hancock’s (and probably at other fabric stores if your area doesn’t have Hancock’s), and they are easy to cut to shape and apply. Like the package says, you just iron them on, and they stay there through heat, humidity, etc. I think they are intended to repair kid’s blue jeans, as most of them are varying shades of blue. But I’ve never had trouble finding black. They are easier to iron into place from above with the roof panel off on Vettes, but I managed to do it OK on my CTSV from fully inside the car without removing the visors. The first time I did it, I was worried about using a full size iron, so bought a cheap, small, travel iron so as not to overlap too much onto the main visor. But by the time I did my third Vette and the CTSV, I had lost that dinky iron, and found that a normal iron works fine without damaging the visor.
Quick Reply: Visor sticker removal
