***LED Puddle light/LED Reflector lights. New from Radioflyer Innovations***
Old 07-30-2013, 01:30 PM
TheRadioFlyer
Supporting Vendor
TheRadioFlyer's Avatar
Default ***LED Puddle light/LED Reflector lights. New from Radioflyer Innovations***
All new product
Something that should have come from the factory:
"Puddle lights" illuminate the area just outside the car when you open the door so you can see where you are about to step. They also make it easy to locate items that may have been dropped on the ground after dark.
Our LED puddle lights use COB (circuit on board) LED technology encased in a waterproof Aluminum heat-sink housing. These deliver significantly more light than Any LED pod or strip we've seen so far.
The Illuminated Door reflectors use a Focused 3watt 60 degree lens LED behind the door reflector to give an added amount of safety when you open your door.
Both lights operate on the same circuit.
Installation of both of these lights is COMPLETELY BOLT/ON plug and play (with the exception of tapping the foot well light harness with the supplied t-taps) No hole drilling is required. These are NOT simple LED strips that will peel off with heat. Both lights attach with 3M heavy duty mounting tape and will remain secure for years.
Package comes with the following items:
- (2) COB white puddle lights with quick disconnect
- (2) Pre-wired 3W LED reflector light housings with clear-mounting tape
- (2) lengths of wire for easy installation in a pre-built harness
- (4) t-tap quick splices for easy tapping.
Order Yours Here:
http://www.shop.radioflyerinnovation...lights-045.htm
Old 07-31-2013, 11:31 AM
TheRadioFlyer
Supporting Vendor
morning bump
Quick Reply: ***LED Puddle light/LED Reflector lights. New from Radioflyer Innovations***
