NO FOBS DETECTED What to do?
#101
I don't think it was what you did. The car already had two fobs programmed to it, one of which was missing (why you were given a second, unprogrammed, one), so it took you straight to #3.
It won't hurt to program the new one as #3 if you think there is no chance of the missing fob being used, because it is still good on this car. If you go the long procedure route, it will keep #2 from being recognized ever again on this car.
With that said I wanted the #2 fob for my wife to use since it would work with all the memory seating and set up for a #2. When you go to #3 and or #4 fobs they do not work, according to the manual for memory settings.
#102
Cruising
i too have the problem on my 2009 vette, i have to change batteries like thy are going out of style. even bought batteries from dealer and a lot of times my car will say FOB not detected. i carry nothing in my pocket but the fob. have used the otherone and the same thing happens.
#103
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,821 Likes
2015 C7 of the Year Finalist
Did you run through the FOB not detected checklist? The RCDLR could be failing. Does the other FOB work in the car?
Elmer
Elmer
#104
Take the FOBs to the dealer and have them checked fr signal sending. This is usually free. If the signal is non-existent or weak, replace the FOB's. I paid $70 from a delaer in TX. 1-800-650-6261 Huffines Chevrolet. The procedure works perfectly. Good luck.
#105
OK! Both my FOB's were bad. I bought a new one and followed the long procedure and went absolutely perfectly as the instructions said. I then went and bought a second FOB a couple weeks later. I tried to start the program and the DIC never starts up. I turned the car off, put the drivers window down, opened the glove box, opened the trunk and turned the key 5 times and nothing. I tried multiple times. Any ideas? Thanks.
#106
I found that it was hit or miss. Lift the drapes and watch the console as you turn the key. Keep turning until the console shows your in the FOB mode. I occasionally had to turn it 7 times. Also after doing it once I thought they might have implemented a failed try lock out timer. It just seemed to not work, so I'd give it a rest for 30 minutes and retry. Wonderful way to spend an evening.
#107
If I get the fob in a pocket with a handful of change and a couple bunches of keys, the DIC will show no fob. take it out and all is well. This has happened several times with the same cure each time.
#108
Fob
Keith has the answer. (I changed the battery as well, and sometimes still get the 'No Fob Detected' msg) When it happens, I flip the fob over through my pants pocket and magically it reappears to the car.
#109
I had a phone charger plugged in under the armrest. Unplugged it and everything when back to normal.
#110
This is really weird, but it has happened to me and a friend of mine. I pulled up to a 7-11 type store and went inside...came back to my corvette and "NO FOB DETECTED" The FOB is in my pocket, so what is the problem?? I called my friend who has a corvette also and he is on the way to get me. Meanwhile, a guy pulls up and says that this happened to him as well. He said his friend who works at Chevy Dealership said to move the corvette back away from the 7-11 Store about 10 feet. My vette is a 6 speed, so I got in...Put it in neutral...Pushed it back about 8 or 10 feet...and it started perfect..!! Didn't put a whole lot of faith in the 7-11 Store Theory, but my friend pulls up next to where I was parked when the FOB would not work and BINGO...his corvette would not start and showed "NO FOB DETECTED" !!!! I don't have a clue what made it do that, but it DID..!! We pushed his corvette back about 10 feet and the FOB worked fine. A Wrecker Driver came by as we were all talking about this and he said he had been to several calls where this had happened near store fronts. His thought were that the Neon Lights or Microwaves (not ovens) but waves coming from the store interfered with the FOB, much like when you have another FOB in your pocket that causes the FOB not to work. I don't know the reason for this...BUT I do know pushing "our" vetts away from the store front allowed our FOBS to work properly.
#111
#112
#113
#114
#116
I've been wearing hearing aids for 20 years and never had a problem with any of the remote "driven" vehicles. And the most recent ones do transmit and receive thru Bluetooth to a remote.
I suspect you just had a week remote battery!!
#117
I too thought it was merely a weak battery and I have only been wearing hearing aids for 6 weeks. I thought it interesting, when I was packing up my car for a track day everything was fine. I wasn't wearing my hearing aids, I can hear myself talking to myself just fine without them. The next morning as I left for the track the fob problems started, and had my hearing aids on for the drive. Since it was 5am. I could get the doors to open using the fob unlock button, ran into problems trying to start the car (no fob detected messages) and it was interesting the car was acting similar to a charging cell phone. I finally figured out the only transmitter I had were my hearing aids. I turned them off and the fob worked better (but not completely). As I stated, a weak fob battery and hearing aids will cause you some problems.
My hearing aids transmit to each other. For example, the volume controls. The left volume control brings the volume down, the right turns it up.
The auto feedback control, automatic gain control, stereo reception all require both sides "talk" to each other.
When I got home, I installed a new battery in my fob and the fob was back in business and 100% reliable. It was a little disconcerting, being two hours from home with a flakey fob. I ended up disabling the auto lock feature while I was at the track, just in case.
I see you are in Arizona, I plan to come down about mid March for the Nascar event. Should be fun, our first time in Arizona (aside from the Phoenix airport) plus it will be nice to get out of the Pacific Northwest rain for a few days.
#118
This is just a friendly reminder that the key will get you into the car, and you can always put the fob in the glovebox slot if you think it is an interference issue, or a low/dead battery--even if the battery is not in the fob, it will work in the slot.
#119
I hope this helps someone. I had a similar issue with my 2012 GS LE several months ago. After two trips to the shop it turn out to be the clips holding the fuse where loose just needed to be tightened up.
#120
Yeep ! fob #2 is dead as my wife calls to tell me cuz she's locked out of the car cuz door won't even open!!! No we don't carry the trunk key like I think we now should. Replaced fob 1& 2 batteries today.
