NO FOBS DETECTED What to do?
#221
Funny, I just bought a 2007 C6 3LT Coupe with 23k on it. Still haven't taken possession of it yet, The dealer has to replace a RR TPMS sensor?
Salesmen has had issues for a week cant start it yada yada.. having perused the forums, told him to put the key in the little compartment in the glovebox ...
Started right up ...
Now only if they could buff the spider cracks from the drivers headlight ...
#223
When I bought my "19 Grand Sport, one fob worked, one did not. After replacing battery in the one that did not work, it still did not work. Went back to the dealer and and it was thought they had given me the wrong fob, Turnedout the new battery was dead. Several times the dash has given me the message "no fob found". When that happens now, I hit the unlock button on the fob, twice, and it usually starts. Several times I have had to insert the fob into the slot on the steering column to start the car, then it works. Sometimes I believe it is because my cell phone is interrupting the signal and sometimes it is the fob for another vehicle. So for far, we have not been stranded anywhere. It keeps it interesting.
#224
Question in learning a FOB.
So bought a 2009 with one FOB with key. I assume it was set as key 3 or 4 as the option menu was unavailible.
So did the long learn and made it 1.
Got a spare and tried to make it #2 but used short learn. I tried it twice but sent it back (amazon 30)
Should I have done the long again but with two fobs or was the 2nd just bad? I did check battery and was 3V
#225
Run the long form again and program ALL the fobs that you're going to use in that one pass thru the form. It should let you program all the fobs you want.
That long form you used eliminated all other fobs.
#226
The short process is only good for adding a previously unlearned fob.
Mine came with one FOB. Did long setup made it #1. Purchased online a second one tried twice and it failed. Unless the short one is only good for FOB 3,4
#227
Received 1,792 Likes
A fresh fully charged fob battery should read 3.3V. Decimals matter here. If it measured 3.0V, it only has 50% charge. I’m not sure if a fob can be programmed with a weak battery, although the antenna behind the slot should induce enough current for it to be recognized. When you took out the battery to test it, did you put it in the right way up? Was the fob oriented in the slot correctly?
The short procedure should have added in the second fob as #2. If the Amazon fob was not OEM, then I’d be suspicious of it. Some have been found to be unable to open the hatch, for example. You might consider getting an OEM fob as your #2.
#228
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,830 Likes
2015 C7 of the Year Finalist
Hello, visiting the C6 FOB section again.
When you do the short program to add a FOB, it will add a new FOB as 3 - 8. THe short program WILL NOT add FOB #2. If you have 1 FOB (1 or 2) and would like to add a 2nd FOB to become 1 or 2, you must do the long program. When you are asked to insert the first FOB, it becomes FOB #1 and the 2nd FOB inserted becomes #2.
ELmer
ELmer
#229
ELmer
ELmer
#230
OK, slowly.
If the FOB being added is not from the dealer anything can happen and usually what happens is bad.
Next, if the FOB is the wrong part number, it won't work.
Next, If you have the 2 FOBs that come with the car, adding FOBs 3-8 is done with the short program and 3 - 8 will have no memory functions.
Next, If you have 1 FOB and would like to add a FOB and do the short program, it'll be FOB#3 with NO memory functions
Next, If you have 1 FOB and want to add a FOB so you're just like the car came with, you do the long program and the first FOB in the slot, during programming, is #1 and the 2nd FOB in the slot, during programming, is #2 and both FOBs will have full memory functions.
Elmer.
Elmer.
#231
OK, slowly.
Elmer.
Elmer.
Perhaps you might consider following the manufacturer's advice, and not insert the Q-tips beyond the recommended depth. Or maybe insert them slowly, so as to give you a chance to back out.
#232
My memory was wrong on the number of FOBs that can be added. The C6 I had was replaced be the C7 I have and it is the one with 8 FOBs.
HOWEVER, this instruction, https://www.ls2.com/boggs/c6/C6FobProgramming.pdf does clearly state 4 FOBs max, fine, I was wrong with the 8 but SINCE I WROTE THE INSTRUCTIONS used in this thread, I recommend you follow the instructions.
You might take your Q-tip out too and try and be civil on the forum. You seem to be upset.
#233
#234
Cclive and I worked in harmony to get the instructions I listed. The If/Then table format is used a lot in training to give an easier path to a set of instructions, rather than big paragraphs and lots of words.
Enjoy your day.
Enjoy your day.
#235
Hey thanks for all the info. Fob #2 will be spare wifes key. So if trunk works or not no big deal. Got another one coming in as per review many have said worked of c6 corvette. Will do long procedure again for both FOBs
#236
I was able to use short procedure to program wife 2 fob. Everything works and all personal settings are able to be set. That first one I got must have been trash. This was a 21.00 ebay special
#237
Glad to hear it. And that verifies the manual which indicates that if only one fob is programmed to the car, the next fob # assigned with the short procedure will be #2.
#238
what someone else said you had to do long for both one and two so this is no true. Saved me 30 minutes
