Run flats confusion.
I'm a little confused. When members say they carry and use slime to fix their flat, are they referring to run flats or regular tires? Should u use slime with a run flat tire?
They are referring to regular tires 99% of the time. The primary purpose of the slime is pretty much the purpose of the run flat --to allow you to drive to a repair facility.
I only use Slime in my riding mower and wheelbarrow tires and wouldn't use it on my car or motorcycle, especially one with TPMS. If needed and if the puncture is in a favorable spot on the tire I'll plug the tire on the spot and pump it back up with the small 12V compressor that I keep in both vehicles. That method has worked well for decades with non-RF tires and RF's shouldn't be any different.
I carry a plug kit and compressor to temporarily repair punctures on my run flats. Run flats will allow you to keep driving at a limited speed and distance without stopping. However, I prefer to plug and go and have a proper plug/patch repair when convenient. Once plugged, I can drive normally without worrying about damage to my tire or rim. I do not use slime, even though some claim no harm on TPMS.
Some may think this is overkill with runflats, but having a flat 400 miles away from home in the middle of nowhere will change your mind. It has happened to me on a ride home from vacation which was only delayed 15 min. for a plug repair!
I drive with run flats, but still carry a can of slime with me. My thought is if I do get a "flat", and its late on a Saturday evening, and i have 300-400 miles to go, not knowing when or where I will find a tire center that can deal with rft's, I see it as insurance.
I have FS WO RFs, but on long trips I'll carry a flat repair kit in case I'm in the middle of Montana or Utah and don't want to drive another hundred miles to find a tire. I'll repair it myself and drive it with no worries. I also would never use a liquid tire repair solution as I doubt they work nearly as well as they're advertised (and) whomever removes that tire will be really pissed when they discover slime inside the tire.
Received 8,930 Likes
Bill
Slime is safe for TPMS. Camaro's come with it so you can even buy the GM slime if you are nervous. Look at it this way, would you rather use slime in the middle of no where and MAYBE have to replace a TPMS which costs under $100 or park your Corvette within 50 miles and the added expenses of days waiting for a tire. I can tell you that a lot of mechanics in the middle of no where (if they are open) will not even attempt to remove a run flat and I'm guessing most C6 owners will not want them to learn on their rims. I asked the only Tire Repair place if they fixed run flats (I had a flat on my Yukon) and he said no way. He won't even remove the run flat tire so the owner's only option would be a tow around 70 miles away.
