Brake Dust; is there really any solution
Old 07-22-2013, 01:41 PM
  #41
Steve_R
Support Corvetteforum!
Steve_R's Avatar
Received 3,289 Likes on 1,399 Posts
St. Jude Donor '12-'13-'14-'15-'16-'17
Originally Posted by RocketDawg
My car has the Z51 package, and I'm pretty sure that GM ceramic pads are part of that option. I get no squeal at all, but I do get a little "groaning" when backing out of the garage. I can live with that ... may just be the automatic adjusters ... adjusting.
There are no "automatic adjusters" on disk brakes.
I agree with other posts about GM pads; I see very little dust with them.
Old 07-22-2013, 02:58 PM
  #42
bucwheat
bucwheat's Avatar
I cleaned my wheels up and put on two coats of Rejex,now they rinse off.
Old 07-22-2013, 09:49 PM
  #43
Oskee
Oskee's Avatar
Originally Posted by carsangelop
Armor All wheel protector May have to reapply every few washes ,but it works
Armor All Wheel protector works great . I apply it every other car wash ....
Old 07-22-2013, 10:08 PM
  #44
RocketDawg
RocketDawg's Avatar
CI 6-7-8 Veteran
St. Jude Donor '09
Page 48 of the 2009 Corvette Owner's Manual: "Every brake stop, the disc brakes automatically adjust for wear."
Old 07-22-2013, 10:30 PM
  #45
Steve_R
Steve_R's Avatar
Of course they do, they're disk brakes. There are no "automatic adjusters" on disk brakes like there used to be on drum brakes. There are no manual adjusters on disk brakes either.
Old 07-23-2013, 04:36 PM
  #46
cessna10
cesssna10
cessna10's Avatar
Originally Posted by Slider-01
Ya but that photo of my wheels is from 95% highway and the Hawk one-piece pads.
The Caebotech pads were worse! I've got a set of them with 1k miles sitting in my basement.
I also have carbo tech along with lots of dust and lots of noise
Old 07-23-2013, 04:57 PM
  #47
JJC5
JJC5's Avatar
There are no "adjusters" on disc brakes. They actually ride on the face of the rotor as opposed to retracting like the shoes do in drum brakes. So with wear on the disc brake pads, you can consider them "self adjusting" since they never retract to the original width of the brake pads. If you raise the wheel off the ground and spin it, you'll hear the pad dragging on the rotor.
Old 07-23-2013, 05:29 PM
  #48
Adam@Amp'dAutosport.com
Supporting Vendor
Adam@Amp'dAutosport.com's Avatar
St. Jude Donor '11,'13
What compound?
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Old 07-23-2013, 06:53 PM
  #49
RobLo
RobLo's Avatar
Akebono Premium, do a search, hardly any negative comments, love mine....
Old 07-23-2013, 10:28 PM
  #50
franman69
franman69's Avatar
AC Delco Ceramics... low cost, low noise.. NO dust... weeks at a time without wiping any dust off my rims... I'll say it again AC DELCO CERAMIC Pads! be DONE with brake dust!... (*not for track use)
Old 07-23-2013, 10:30 PM
  #51
Slider-01
Slider-01's Avatar
I've been told they are not available for the GS/ZO6
Old 07-24-2013, 08:32 AM
  #52
Thomasmoto
Thomasmoto's Avatar
Received 1,505 Likes on 1,027 Posts
This is my question as well.
Old 07-24-2013, 08:43 AM
  #53
franman69
franman69's Avatar
Hmmm.. this may be true. I would try Hawk Ceramics or the Akebono Premium ceramics in that case. THe Akebono get great reviews but are pricey. Hawk makes great stuff, but I don't have any experience with their Ceramics directly. Such a shame. I can pickup four corners in the AC Delco Ceramics for my Z51 on Amazon for like $77...
Old 07-24-2013, 08:44 AM
  #54
FloydSummerOf68
FloydSummerOf68's Avatar
I just don't worry about brake dust on the inside of the barrel. Keep the outsides clean and be happy. If you keep a sealant on the wheels it should take less than 2 minutes to wipe them all down during a wash.
Old 07-24-2013, 12:09 PM
  #55
truckplay
truckplay's Avatar
Default you are a SICK MAN
cleaning the barrels
I have been using Rejex on the face of the wheels since I found out about it for a few years now and have always been able to just spray them down with the hose and dry them with towel & they come clean pretty easy, even after a day in the mountains.
Old 07-24-2013, 05:52 PM
  #56
RobLo
RobLo's Avatar
Akebono Premium's about $140 to my door from RockAuto, I didn't think that was too bad....unlike Carbotech, over $500 for 4 corners. But in fairness to C/T, I believe they can be used for race applications. If I tracked my car I'd probably use the C/T's....
Old 07-24-2013, 05:59 PM
  #57
franman69
franman69's Avatar
Yes I use (expensive) C/T pads for Track days.. XP-10 and XP-12.. They make a TON of noise and a BOAT LOAD of dust and are not indicated for street use, but they don't fade when brake temps go through the roof at the track.... Seems like the Akebono Premium's are the way to go for GS/ Z06 guys on the street looking for a low dust ceramic pad.
Old 07-25-2013, 11:45 AM
  #58
Z_Monzter
Z_Monzter's Avatar
AC Delco Ceramics is not offered for GS/Z06
Akebono Premium is not offered for GS/Z06
Hawks Ceramics are only offered for Coupe, Convertible or ZR1 not GS/Z06.
What's the best option for GS/Z06 other than Carbothech???
Old 07-25-2013, 12:45 PM
  #59
Mac-427
Mac-427's Avatar
Default Re-Best Solution Question
I changed My 427 Vert to premium ceramic padlets from Orielly Auto Parts. As I recall, the fronts were part # 1419 and the rears were 1419A. Both sets were around 100 bucks total. I can wipe the wheels inside and out with a dry microfiber after driving and get almost no brake dust. The replacement process was a snap. Also, virtually no squeaking. Orielly has both front and rear although I had to special order the rear set. Had everything within a couple of days. My understanding is that the pads are made by Bosch.
Quick Reply: Brake Dust; is there really any solution
