Fog Lights Adjustment
Old 07-15-2013, 01:17 PM
Nosferatu
Nosferatu's Avatar
St. Jude Donor '14
Default Fog Lights Adjustment
Is there a way to do this? I know you can for the standard headlights.
The reason I ask was I noticed when I run the fogs with the low beams it looks almost like when I have the car on high beams. With the fog lights on I get great peripheral view and it also lights up much higher further down the road than my low beams. When running them people flash the brights at me. When I don't run fogs it's a non-issue. Thanks.
Old 07-15-2013, 01:39 PM
RLSebring
Supporting Vendor
Support Corvetteforum!
RLSebring's Avatar
Location: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
There's an up/down adjustment. Just ahead of the outer air damns on each side is a hole you stick a 7mm allen up into and turn one way or the other.
zzjakect (11-12-2016)
Old 11-06-2016, 08:16 PM
Obiwan-J.M.
Obiwan-J.M.'s Avatar
Default C6 Fog Light Adjustment
I have just replaced the fog light housings in my C6 vert and was looking to adjust the fogs. The housings were from a 2012 C6 and were adjusted for that vehicle. I am looking for fog light adjustment instructions. The previous post said there was an adjustment from the bottom. I did not find any adjustment on the underside of the housing but there is one at the back that has a 10 mm nylon drive. I have not tried them yet, but will post with further info. The white 10mm is in the upper right corner.
Old 11-06-2016, 09:21 PM
Knob Jockey
Knob Jockey's Avatar
St. Jude Donor '11-'12-'13-'14-'15
Old 11-07-2016, 12:50 AM
CorvetteSparky
CorvetteSparky's Avatar
Wow, this is very timely information. I just notice a couple of nights ago that my fog lights seem to be pointing at the ground. They do no good when they are on.
Old 11-07-2016, 12:53 AM
919cw313
919cw313's Avatar
Received 2,683 Likes on 1,408 Posts
2018 C6 of Year Finalist
Yes, very timely...
Old 11-07-2016, 08:28 AM
Boomer111
Boomer111's Avatar
With many years of driving I have always found fog lights to be marginal at best.
Ya gives some help but still slowing down is the best remedy.
Out in in California we get some real heavy Central Valley fog. I used to fight it alot also along the coast Hwy1 between Santa Cruz and San Francisco.
Fog lights useless.
Big pair of steel ***** priceless.
Old 11-07-2016, 01:51 PM
dlcain
dlcain's Avatar
Can someone tell me what the part number of the fog light bulb is? I can't seem to find it in my 2006 manual. Thanks.
Old 11-07-2016, 02:39 PM
fgriff1
fgriff1's Avatar
Fog Light Bulb Front
Part Number:9145
Old 11-08-2016, 07:59 AM
ben dover
ben dover's Avatar
Location: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
If fog is a problem, then bright white LEDs are not the answer.
Old 11-08-2016, 08:17 AM
Corvette_Ed
Corvette_Ed's Avatar
Received 2,843 Likes on 1,801 Posts
Fog lights useless.
I used to drive in the same fog up in northern Cali. The thing is, if the bulbs in the "fog" lights are white, they're not fog lights; they're driving lights. They are only true fog lights when the bulbs are yellow, which cuts through even the nasty, blinding fog seen in northern Cali.
Old 11-08-2016, 11:03 PM
Boomer111
Boomer111's Avatar
Yes the yellow is better but still very iffy.
The problem is the light gets reflected and splatters all over causing more blindness.
I ran yellow on the big rig and still found the fog scary as all get out.
On another subject driving at night with falling snow is kind of tough too, at least for me. very disorienting.
To Fog Lights Adjustment
Quick Reply: Fog Lights Adjustment
