What 120 V Tire inflator is the best?
I bought the Kolbalt 120V/12/vdc at Home Depot and it’s A P O $$.
Don’t mind paying for the best!
Robert
Robert
Most all of them are Taiwan, China, etc these days. So I buy 'a decent one' at an inexpensive price knowing it will not last forever. However the one I have now seems be the best quality I have had and the darn thing is hard to kill - it just keeps on pumping.
Campbell Hausfeld 120 Volt Home Inflation System $36.99 at Amazon.com
You must have the same one I have. About 5 inches square, 12-14 inches long. I looked on the B&D website not too long ago and couldn't find it. I've had it about 15 years and it's still going strong and is fast. Looks like I may have to replace the air hose before long, but it has clamps on both ends that look like they would be easily changed. Might even just cut a bit of the hose off where it stays bent.
Thanks All. I think I’m going to give up on the portable one and go with a real compressor. I need 90 psi for the boat trailer tire. I’ve already spent $100 on this one and it’s going in the Bay
These ViAir units are the best quality ones I've found to keep in the car.
For the house I have a craftsman 27 gallon.
http://www.amazon.com/VIAIR-85P-Portable-Air-Compressor/dp/B0036E9VB6/ref=sr_1_3?ie=UTF8&qid=1373464233&sr=8-3&keywords=air+compressor
I went through several cheap ones that took forever to fill up a tire, and made tons of noise before I got one that actually works.For the house I have a craftsman 27 gallon.
The one I 'suggest' in Post # 3 is a real compressor - and it's under $40. - has no problem with any tire inflation needs I've had - I'm just sayin you don't need to spend a fortune to inflate tires
