NPP exhaust option
Old 07-03-2013, 09:05 PM
Bcmayo
Bcmayo's Avatar
Default NPP exhaust option
Still looking to buy my first vette. Is there a way to tell if a c6 is equipped with the NPP exhaust option by VIN number?
Old 07-03-2013, 09:15 PM
Red08
Red08's Avatar
Received 1,441 Likes on 780 Posts
Not sure if you can tell by the VIN, but its easy to know when you are with the car
Old 07-03-2013, 09:21 PM
steveb601
steveb601's Avatar
I can't answer the VIN question, but you can also add NPP with an aftermarket kit and NPP style mufflers.
Old 07-03-2013, 09:34 PM
corvette624
corvette624's Avatar
Call your local Chevy dealer's parts department with the VIN and they can tell you. I hope this helps.
Old 07-03-2013, 09:41 PM
raspyc6
raspyc6's Avatar
just open the glove compartment and the option code NPP will be listed. A less intensive option would be to look for the venturi valve equipment out back
Old 07-03-2013, 09:54 PM
Bcmayo
Bcmayo's Avatar
Thanks!
Old 07-03-2013, 10:12 PM
Tally Ho
Support Corvetteforum!
Tally Ho's Avatar
Location: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
Received 1,426 Likes on 774 Posts
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Exactly. The VIN will tell you nothing about options. From 2010 on the VIN will tell you what base packages (1LT, 2LT, etc.), GS, Z06, and ZR1 packages. All other options can be found on the glove box decal or a build sheet/window sticker if you have one.
If your inner exhaust tips have the butterfly valve, the car has NPP. Whether it is factory optioned or owner added can only be told by the option sheet.
Old 07-03-2013, 10:30 PM
spdkilz911
spdkilz911's Avatar
Look from this angle or have them send a picture. I thought I had a closer one, but you can see the valves on the two inside pipes if you look close.
Edit: Found one:
Old 07-03-2013, 10:45 PM
at7000ft
at7000ft's Avatar
With such a small percent of used vettes with NPP it is much easier to add yourself. Bought a used set for $600 for mine, or their is more expensive aftermarket options.
Old 07-04-2013, 08:39 AM
Bcmayo
Bcmayo's Avatar
Where did you find them?
Old 07-04-2013, 08:50 AM
spdkilz911
spdkilz911's Avatar
They pop up in the For Sale section from time to time.
Old 07-04-2013, 08:59 AM
boraxman
boraxman's Avatar
I really like the NPP's
Old 07-04-2013, 09:08 AM
sar10
sar10's Avatar
I posted in the 'Wanted to buy" section and received a response and purchased as a result.
Old 07-04-2013, 10:09 AM
DigitalWidgets
DigitalWidgets's Avatar
Heck you can tell if a vette has NPP and the fuse pulled from a distance. Just look at the inside pipes. If they're blacker than the outside ones, the car has NPP and the fuse is pulled (or M2W, or a 2 dollar switch like I have).
This is the classic "I've got the fuse pulled" look:
Old 07-04-2013, 10:49 PM
icntdrv55
icntdrv55's Avatar
New '13 GS owner with the NPP option. Asking the question: Is the valve operated by solenoid or vacuum? In reading a few threads, it sounds like there is a way to open the valve all the time vs just above 3K RPM with heavy foot. Simple fix? Pulling the fuse doesn't send a code to the ECU?
So I gotta ask: Is the non-NPP (standard) exhaust like the NPP option in quiet mode? Or full open mode? If the latter, why do dealers order the extra cost NPP option only to have new owners immediately disable it?
Old 07-04-2013, 11:21 PM
steveb601
steveb601's Avatar
NPP valves on the mufflers are controlled by vacuum. My car didn't come with it but i used the aftermarket ones from B&B and routed the hoses, etc. The B&B sound similar to normal exhaust when the valves are closed and louder when open. Some people disable them and keep them loud all the time...others prefer to be able to control them when they want. Also by using one of the aftermarket switches you can control it manually vs. hitting the RPMs, etc.
Old 07-05-2013, 02:51 AM
Stavesacre21
Stavesacre21's Avatar
NPP... the best option I never knew I wanted. Absolutely love mine, although I would very highly recommend either a mild to wild controller or some sort of a hardwired switch so that you have total control of the NPP baffles.
They are very easy to spot if you look at an exhaust from behind. The solenoids above the mufflers stick out like a sore thumb. Some people cover them although I personally like them.
To NPP exhaust option
Old 07-05-2013, 07:02 AM
MikeyTX
MikeyTX's Avatar
Received 2,186 Likes on 1,337 Posts
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
If buying used, as mentioned, simply bend down and look for the valve actuators on the pipe coming out from the mufflers. If new, it will be listed as an option on the window sticker. Also, the exhaust tips are slightly larger on the NPP vs the base non NPP exhaust.
Old 07-05-2013, 03:51 PM
at7000ft
at7000ft's Avatar
Old 07-05-2013, 03:53 PM
at7000ft
at7000ft's Avatar
And I read that the C7 will use some sort of electronic acutator for the NPP.
Quick Reply: NPP exhaust option
