Wrecked my car. Long story
Old 07-02-2013, 12:06 AM
paganharley
paganharley's Avatar
St. Jude Donor '11
Default Wrecked my car. Long story
I was not hurt just stiff and sore from it. It all happened in a middle of a right hand turn at a red light. The light was green, as I was making my turn I did not see the sand in the road. Well when I hit it as I was making my turn my back end came around on me. I was running 26 miles per hour by my hud.
I had all the traction controls on. I went nose first into a bank of dirt and then it flipped around and went in backwards into the bank.
I was on a run with my vette club when all of this happend. Anyway, the adjuster sent it to one shop and they could not fix it. Now they are wanting to send it to another one.
When I tried to put my top back up the windshield was laying back a good 4 inches. There was no way to latch the top down.
It took the radiator out,the front nose was gone , radiator fluid was every where. All 4 rims now have some kind of damage to them.Broke the bead on the rear two tires.
They gave a estimate of 6k in damage. I donot see how they came up with such a low figure. I know there is more than cosmetic damage done. I guess time will tell.
Last edited by paganharley; 07-02-2013 at 02:13 AM. Reason: I do have some pictures
Old 07-02-2013, 12:28 AM
Bat Man
Bat Man's Avatar
Ive never had my tc or ah not get me out of a situation especially at low speeds like 26 mph.
You may want to get your system checked, and tires as well. Good luck on repairs
Old 07-02-2013, 12:37 AM
Ryan5508
Ryan5508's Avatar
sorry to hear. hopefully your back up and running soon!
Old 07-02-2013, 12:41 AM
paganharley
St. Jude Donor '11
I will tell them in the morning to check it. The active handling did not show up either.
Old 07-02-2013, 12:56 AM
peter pan
Life Time NCM #2196
Support Corvetteforum!
peter pan's Avatar
Received 1,096 Likes on 808 Posts
Glad you are ok and good luck with the repairs
Old 07-02-2013, 01:01 AM
Doughan
Doughan's Avatar
Elite Member
Cruise-In III Veteran
Dang sorry to hear but you're okay which is what matters. The Vette can be repaired or replaced.
Old 07-02-2013, 01:42 AM
arrie
Simplify
arrie's Avatar
Location: forging ahead...making up for lost time and embracing each day thankful to be alive.... nj
St. Jude Donor '13-'14-'15
~~~ CFOT Book Folder ~~~
sad for car - good for you that you weren't seriously hurt.....
it would KILL me to wreck my car.....
Old 07-02-2013, 02:08 AM
paganharley
St. Jude Donor '11
http://i1314.photobucket.com/albums/...ps8593eecd.jpg
http://i1314.photobucket.com/albums/...ps1d8af9f2.jpg
http://i1314.photobucket.com/albums/...pscc4de9ce.jpg
http://i1314.photobucket.com/albums/...ps349fd293.jpg
I hope these links work
Old 07-02-2013, 02:21 AM
paganharley
St. Jude Donor '11
http://i1314.photobucket.com/albums/...ps9a54bc22.jpg
Old 07-02-2013, 02:37 AM
paganharley
St. Jude Donor '11
http://i1314.photobucket.com/albums/...ps6338c9e2.jpg
Old 07-02-2013, 02:45 AM
BettermostCorvette
BettermostCorvette's Avatar
Sorry to hear about your car but at least you are OK. Let me ask are both doors opening and closing properly? I'm hard pressed to understand why the windshield would be bent backward did the air bags deploy by chance? Let me tell you now to replace all four wheels and tires alone its going to cost 4 grand so whom ever gave you that 6 grand figure has there head up there a$$. Don't be surprised if they total it once they get to crunching the real numbers. I'm going to guess just from what I can see a repair bill somewhere in the $15-18K range. Usually most underwriters will total only if the damage costs are within $3K of wholesale value of the car.
Old 07-02-2013, 03:08 AM
paganharley
St. Jude Donor '11
The airbags didnot deploy. The door opened ok as far as I remember. I was sort of out of it. It broke the beads on both rear wheels. I just dont see them just putting the cosmetics back on and giving it back to me.
I feel the same way you do that they should replace rims and tires.
I got a feeling this is going to be a long process.
Old 07-02-2013, 03:10 AM
BettermostCorvette
Who is your underwriter? Talk to the adjuster first, make it very clear to them before any work is started what you will and will not accept.
Old 07-02-2013, 06:26 AM
davidtcpa
Go Canes!
davidtcpa's Avatar
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
As long as you're ok. The car can be replaced.
Old 07-02-2013, 06:38 AM
AORoads
AORoads's Avatar
Received 2,478 Likes on 1,941 Posts
St. Jude Donor '15
"In honor of jpee"
hope you are ok.
Old 07-02-2013, 06:54 AM
VatorMan
VatorMan's Avatar
CI 6-7-8 Veteran
St. Jude's Donor '06-'10-'11, '15
Sand in the road ? That's a new one.
Old 07-02-2013, 07:23 AM
su8pack1
su8pack1's Avatar
Glad you're ok. Good luck with repairs.
To Wrecked my car. Long story
Old 07-02-2013, 08:45 AM
Ferocious C6
Ferocious C6's Avatar
Next time, lay off the throttle on those turns.
Old 07-02-2013, 08:55 AM
Triumph Jerry
Triumph Jerry's Avatar
I know it looks bad, but they can fix it
Old 07-02-2013, 08:56 AM
Walt White Coupe
Walt White Coupe's Avatar
Received 2,223 Likes on 1,140 Posts
Sorry for your misfortune. I don't see anyway that the windshield moved at all based on what I see from your pictures and it's surely not totaled.
Quick Reply: Wrecked my car. Long story
