Battery Tenderquick question
I've never used one of these before but am going to be away for 5 weeks and for the first time will use one of these on my corvette. My question is can you close the hood while connected to the battery or leave the hood completely open while on the tender? Not sure if leaving the hood open so long will adversely affect my hood's two cylinder pieces that keep the hood open or not. Thanks!
i plug mine in everytime i park it in the garage. i run the cable over the fender and rest the hood on the latch, without latching it. i would hate for the hood to come crashing down, god knows what would crack - break
But I think it's much easier to connect with a cigarette adapter, like this one for the CTEK:
From another thread:
Plug into the center console outlet and leave the console lid open... effective reminder to disconnect it before driving away.
And if you run the cord thru the notch in the door sill, make sure you don't crimp the cord -- it should move easily when the door is closed.
This definitely works, no problem. You can use a car cover, too.
http://forums.corvetteforum.com/c6-c...e-adapter.html
