Window problem
Window problem
I got a problem with my driver window. When I close my door, the window won't go all the way up, it stops about quarter inch from the top.
Also after that the door won't open, it seems like the window doesn't go fully up and the care thinks the door is still open. Well after I drive for awhile the window finally goes up all the way by itself and everything is fine. I tried re-indexing the windows but no luck.
Anybody know whats going on?
There are computer modules in the doors that control those things. I have heard of them going bad and causing window issues like those you are experiencing, and failing to the point where people had to use the emergency release to open their doors. I would start there.
Just got my vette the other day but had similar problems. From the outside of the car close the door and just touch the pad that opens the door from the exterior (dont actually open the door) just barely touch the pad and see if the window indexes all the way up then. If it does that then your exterior door handle/pad is corroded and needs replacing. Dont ask why but when I am in the car and the window doesnt index all the way up I cant open the door, but if its all the way up I can open the door. So check to see if the exterior pad/handle is the thing making it act up. Good luck!
