who has done an axle back exhaust swap in the driveway, got a couple questions
Old 03-27-2013, 06:39 AM
blk05coupe
blk05coupe's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Default who has done an axle back exhaust swap in the driveway, got a couple questions
In a few weeks I’ll be swapping our B&B bullets for a Z06 bi-mode exhaust. Question is how difficult is the swap and how high do you have to get the rear end to rotate them in and out.
thanks
mike
Old 03-27-2013, 06:56 AM
LFZ
LFZ's Avatar
On big stands, lift as high as possible...I'd put the front wheels on race ramps, and place stands as high as they go on rear frame jacking points. To make life so much easier especially on stands, you can take out the heat shield above the exhaust and lower the rear cradle about 1.5" to give you more room.
Old 03-27-2013, 07:11 AM
MikeERWNC
MikeERWNC's Avatar
I just lifted high enough so I could roll to the front of the H pipe.
I loosen all the brackets then dropped the h- pipe at the front of the car.
Next dropped the H-pipe at the axle.
Finally remove the bolts holding the exhaust brackets to the rear of the car.
The exhaust will then slide over the axle and out the back of the car.
I have an A6, the SLP could not get by the shift linkage so I popped it off and hung it out of the way.
Once you have the exhaust off, replace your differential fluid.
With the exhaust out of the way, it is extremely easy to fill the rear end. And it can't hurt.
Old 03-27-2013, 07:23 AM
mcandrew67
mcandrew67's Avatar
Received 1,013 Likes on 599 Posts
2016 Corvette of Year
2015 C6 of Year Finalist
I did it on race ramps in the garage, I guess it depends how big your belly is too
Old 03-27-2013, 07:57 AM
ben dover
ben dover's Avatar
Location: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
30" would be good.
Old 03-27-2013, 08:48 AM
MikeERWNC
MikeERWNC's Avatar
Originally Posted by ben dover
30" would be good.
That's what she said.
Old 03-27-2013, 09:07 AM
Airwolf
Airwolf's Avatar
Location: ********************* Florida's Space Coast *********************
Just installed mine Monday.
I used race ramps (backed on to them) and jacked up the driver side till the wheel left the ground and installed a jack stand. Did the same for passenger side. Removed the nuts for the spring holders first, then removed the connection for the x-pipe at the front, using one of the flanges to hold the assembly up on one of the lower bolts. Next I loosened the clamps at the rear of the x-pipe and disconnected the pipes. These required a little force to unseat, and my car only has 400 miles on it, so more mileage may equal more force!
Next I lubed the rubber bushings and pushed the drivers side exhaust out of them and then removed. Did the same for the passenger side. You will have to turn as you remove but they come right out.
Install was a little more of a pain as the drivers side pipe seemed to want to hit the tranny brackets. I managed to have about a half inch of room, but wish I could get more. I will be checking in a week to make sure nothing shifted. Oddly, alignment was near perfect and only required a little shift to the drivers side.
It can be done on ramps as stated above, but next time I would want to do it on a lift. It took me 1.5 hours, most of it making sure everything had clearence. Coud be done in an hour. Make sure you have deep sockets and a set of open ends...
Old 03-27-2013, 10:12 AM
Top_Fuel
Top_Fuel's Avatar
Check out THIS thread with instructions and pictures.
I basically did what this guy did. I backed up onto 10" high ramps (note...most cheap ramps like Rhino Ramps are only 8" tall). I had the front tires sitting on pieces of 2x10s for a little extra clearance. Other than that I didn't raise the front of the car at all.
Old 03-27-2013, 10:42 AM
Ratchet Thunderbolt
Ratchet Thunderbolt's Avatar
Default Npp
I swapped out my 09 standard exhaust mufflers for the NPP mufflers right after I purchased the car. At the same time I installed the NPP exhaust controller kit from Sunset Orange Creations. It was pretty easy. I dropped the exhaust from the cats back which helped getting the mufflers off and on. I used my race ramps to get the rear of the car up. It took me a couple of hours and two beers to complete the job. Here are a few pics.
Old 03-27-2013, 10:55 AM
blk05coupe
blk05coupe's Avatar
Cruise-In V Veteran
great info.... thanks guys, looks like a doable saturday job.
mike
Old 03-27-2013, 10:58 AM
Top_Fuel
Top_Fuel's Avatar
Originally Posted by Ratchet Thunderbolt
I swapped out my 09 standard exhaust mufflers...I used my race ramps to get the rear of the car up
Great pics! These help illustrate that you don't have to raise the whole car up to access the bolts at the front of the mid-pipe. It probably doesn't hurt, but it's not mandatory. Just back it up on some 10" tall ramps and you're good to go.
Old 03-27-2013, 11:38 AM
0Fred@ReverseLogic
Former Vendor
Fred@ReverseLogic's Avatar
Actually they are closer to 6" high.
Originally Posted by Top_Fuel
... I backed up onto 10" high ramps (note...most cheap ramps like Rhino Ramps are only 8" tall).
Old 03-27-2013, 12:42 PM
Top_Fuel
Top_Fuel's Avatar
I believe it...whatever they are, they aren't high enough! I used Rhino Ramps to do my exhaust swap, and I still had to jack the rear end up and stack some sections of 2x10s under the ramps to get another few inches of lift.
Old 03-27-2013, 12:53 PM
iw172
iw172's Avatar
Location: Retired early,everyday is Saturday...Hocking Hills Ohio
I'm gettin ready to do this when the weather breaks here, this will help out.
Old 06-20-2013, 09:26 AM
mefly2
mefly2's Avatar
I used 2 x 10 boards stacked on top of cement blocks after jacking up with floor jack ...
To who has done an axle back exhaust swap in the driveway, got a couple questions
Quick Reply: who has done an axle back exhaust swap in the driveway, got a couple questions
