Front licencse plate bracket
Old 06-17-2013, 06:25 AM
John 511
John 511's Avatar
Default Front licencse plate bracket
Does anybody know where I can get a nice looking front bracket, for C6.
Old 06-17-2013, 06:38 AM
R&L's C6
Support Corvetteforum!
R&L's C6's Avatar
Received 1,246 Likes on 705 Posts
http://www.topflightrepro.com/
I have their removable one...
Attachment 47727665
Old 06-17-2013, 06:44 AM
6893Vette
6893Vette's Avatar
Originally Posted by R&L's C6
Old 06-17-2013, 06:50 AM
Top Flight Reproductions
Top Flight Reproductions's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15
We have them in stock and ready to ship
http://www.topflightrepro.com/corvet...brackets.shtml
VET4LES
VET4LES's Avatar
I made mine with misc. parts I had in the garage. No holes were drilled or tape used.
Old 06-17-2013, 07:08 AM
GOLD72
GOLD72's Avatar
Received 1,105 Likes on 718 Posts
me too.
Old 06-17-2013, 07:27 AM
dvilin
dvilin's Avatar
Received 7,922 Likes on 4,808 Posts
If you are going to get one this is the best out there.
Old 06-17-2013, 08:19 AM
Don-Vette
Don-Vette's Avatar
Another vote for Top Flight!!
Old 06-17-2013, 08:38 AM
beepster
beepster's Avatar
If you have to run a front tag, this is the one!
Old 06-17-2013, 08:46 AM
EBvette02
EBvette02's Avatar
Top Flight!
Old 06-17-2013, 09:03 AM
Geometrix
1st Gear
Geometrix's Avatar
Default Front License Plate
Take a look at the 'Show n Go' License Plate Frame. I put the remote controlled one on my new C6 and really like it.
http://www.amazon.com/s/?ie=UTF8&key...l_7hh2i79d28_b
Old 06-17-2013, 09:50 AM
billyboy47
billyboy47's Avatar
St. Jude Donor '17
i live in pa., thank god i don't need a front bracket for my car. THOSE THINGS ARE REAL UGLY. i think i would get the motorized one, no doubt. if i had to pay 500 to hide it, i would. sorry guy's, jmo.
Old 06-17-2013, 11:47 AM
R&L's C6
R&L's C6's Avatar
Unless you do a lot of car shows, I dont really get the point of those.
Old 06-17-2013, 01:19 PM
bill gsport
bill gsport's Avatar
Made two little angle brackets for the top of the plate. I mounted them at the top of the grille (sandwiched the grill between the bracket and bracket backing plate....no grille damage or holes to drill). I have a small aluminum angle bracket at the bottom attached to the license plate and body with double foam tape...license frame is close to, but not touching the body (again, no holes or damage). This angles the plate back under the body overhang at the top with the bottom overhanging the body slightly at the bottom. Looks good (as good as a front plate can) and better than the available brackets IMO. Cost wasn't really a factor, just didn't like what was available.
Old 06-17-2013, 01:30 PM
Green_2027
Green_2027's Avatar
I just installed the one from Zip. IMO the ones that put the plate right square in the center look awful. The Zip one is a little offset to the driver's side, and really low. And, it is very, very easy to remove and put back on if you want to.
Old 06-17-2013, 02:21 PM
Jimailer
Jimailer's Avatar
I have Show-n Go and as you can see I keep it tucked under, most of the time. If I get stopped, only happned once I say just washed the car and forgot to put it out.
I don't like it for the reason the car is so low it hits all the time, speed bumps, drive ways also the motor is weak and a little dirt on it and it doesn't move.
Old 06-17-2013, 04:03 PM
Tbox
7th Gear
Tbox's Avatar
Mine is from Zip Corvette. It is removable and mounts low on driver's side.
To Front licencse plate bracket
Old 06-17-2013, 04:09 PM
redrckt97
redrckt97's Avatar
check with your state -- here in Tx they just made fold-aways illegal.
I use a Top Flight -- good product
Old 06-17-2013, 04:16 PM
Tbox
7th Gear
Tbox's Avatar
Mine from Zip is not a fold-away. It is held on by two detents and pulls off easily.
Old 06-17-2013, 04:35 PM
richietables
richietables's Avatar
Yup! Me too.
Quick Reply: Front licencse plate bracket
