Second gear tire chirp
Old 06-17-2013, 04:54 PM
graveyard
graveyard's Avatar
Default Second gear tire chirp
Any you guys get your car to bark the tires when it goes in 2 gear?
I had mine in sport mode the other day and just floored it from a stop with no button pushed TC and all was still on and when the change to 2nd come in the tires chirp a little.All I have is a vararam intake.
Old 06-17-2013, 04:56 PM
REDFIVE48
REDFIVE48's Avatar
Originally Posted by graveyard
Any you guys get your car to bark the tires when it goes in 2 gear?A6
I have to be real careful not to spin the tires on 2nd gear shift. First time I did it I got the car so sideways so violently that I hit my head on the roof above the door. I am much more conservative with the gas pedal on 1 - 2 shift these days.
Old 06-17-2013, 05:00 PM
flange
flange's Avatar
St. Jude Donor '14
its easier than you think with the manual, second, third..
Old 06-17-2013, 05:01 PM
Seadawg
Seadawg's Avatar
I'm assuming you have an auto, because my squalls very loudly when I grab 2nd with my 6-speed.
It would spin like crazy and only whine with the Goodyears, but the Bridgestones just bite and let you know you have broke traction.
Sounds like the old days with the musclecars when I get on it hard.
Old 06-17-2013, 05:05 PM
slolane
Support Corvetteforum!
slolane's Avatar
CI 7-8-9 Veteran
St. Jude Donor '07-'08 & '12
2nd and 3rd in my manual
graveyard
graveyard's Avatar
Sounds great guys,just had the car for a little while,still trying everthing out and getting use to it.LS2
Old 06-17-2013, 05:07 PM
ATC399
ATC399's Avatar
i get a chirp in 6th...lmmfao
Old 06-17-2013, 05:31 PM
dvilin
dvilin's Avatar
Received 7,929 Likes on 4,810 Posts
Old 06-17-2013, 06:06 PM
Boosted Josh
Boosted Josh's Avatar
Yep, the Goodyears just spin without making much of any noise. They also don't allow full throttle in first or second without spinning, or that could be the LS7
Can't wait for my Michelin super sports to arrive.
Old 06-17-2013, 06:24 PM
R0NIN
R0NIN's Avatar
hahaha, this happens to me all the time in my manual 2009 LS3 coupe.... The questions I should be asking people here is... how the heck do you launch this baby without breaking free and burning rubber through the intersection (although that is fun too)...
Old 06-17-2013, 06:25 PM
VET4LES
VET4LES's Avatar
It's normal. Be careful it can get away from you.
Old 06-17-2013, 06:40 PM
billyboy47
billyboy47's Avatar
St. Jude Donor '17
my a6 chirps in seventh.
Old 06-17-2013, 07:52 PM
trebor8008
trebor8008's Avatar
My manual 07 used to chirp in nuetral, then I changed out the Harmonic balancer
Old 06-17-2013, 08:37 PM
ATC399
ATC399's Avatar
Old 06-17-2013, 08:54 PM
Top_Fuel
Top_Fuel's Avatar
Originally Posted by trebor8008
My manual 07 used to chirp in neutral, then I changed out the Harmonic balancer...
Old 06-17-2013, 08:58 PM
Firewater Burns
Firewater Burns's Avatar
Somewhere in the massive FAQ, there is a guide on how to launch the car well. Under the racing guides. I dont go to the track often, so I dont get much practice, but I think its something along the lines of put RPMs around 5k, pop the clutch, dont move the gas until you hook, then punch it and go. Don't forget to take off traction control.
I have hooked the GY run-flats better than I expected after following the advice in the FAQ.
On the street, when I accidentally break free, the GYs just sound like there is an inch of sand between the wheel and the pavement. In some parts of Texas, this may actually be the case.
Old 06-17-2013, 09:44 PM
Gearhead Jim
Gearhead Jim's Avatar
Received 2,051 Likes on 1,362 Posts
St. Jude Donor '13
2009 A6, Performance Axle ratio, Michelin PS2 runflats.
I roll into the throttle very quickly, but not quite a mash. Then at about 20 mph/3,000 rpm, I may have to ease off a little as the engine gets into the good part of the power band.
This varies widely depending on temperature and road surface.
To Second gear tire chirp
Johnathon59
Johnathon59's Avatar
My '13 GS 6 manual is very dangerous on concrete surface NO bite at all is much better on warm asphalt, will chirp going into 2nd & sometimes 3rd depending on shift point RPM's
Old 06-17-2013, 10:30 PM
360Rocket
360Rocket's Avatar
St. Jude Donor '12-'13-'14
I have an A4 and it spins in 2nd and chirps in 3rd. I had the shift pulswidth shortened and the shift pressure adjusted to 60% over factory in my transmission tune. I love those barking 19's.
Old 06-17-2013, 10:48 PM
loudvolvo
loudvolvo's Avatar
stock LS2 here on GY runflats. spins going into 2nd and chips em goin into 3rd!
Quick Reply: Second gear tire chirp
