Looking for shop to install harminic balancer - Philly area
Hi all. I'm looking for references for a shop to replace my harmoinic balancer. I live in the Philly suburbs. I can always go to the dealer as last resort.
Cheers!
Joe
Cheers!
Joe
Location: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Received 2,239 Likes
County Corvette in West Chester they can handle it for you.
Just drive over to ECS and be done with it. Have a good balancer put on too. Your only an hour away
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
either them, or Phoenix Performance in Phoenixville.
Premium Supporting Vendor
We would certainly be happy to do it for you. We have done several including my own recently!
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
Former Vendor
We are not to far from you. Give us a call and we can get everything taken care of. If you get the car to us at 9am then we can have the balancer replaced by lunchtime.
Josh Hicks
(302)838-2188
horsepoweraddicts@gmail.com
Josh Hicks
(302)838-2188
How do you know you need it? My lower belt was squeaking, I had the belt replaced, all was good for a few weeks and now it is squeaking again. It only squeaks for about 10 minutes and then it goes away.
Retired & lovin' it!
The harmonic balancer (or HB) is the large pulley on the nose of the crankshaft at the front of the engine. The HB drives the serpentine belt around the other accessory pulleys. Corvettes (& other GM models) have had reliability problems with this part for many years & it's frustrating for all of us that GM hasn't come up with a better design. In one instance, since GM uses a bolt & friction fit rather than a keyed connection in the nose of the crank, the pulley can work loose & wobble on the shaft. In the second case, the pulley is a 2-part design (inner/outer sleeves) which may start to separate & also wobble. The symptom is a squealing noise from the belt. Unfortunately, repair is expensive since several sub-assemblies have to be removed in order to get to the HB. Hope this explanation helps you....
Thanx Dave for a clear and well written explanation. Hate to appear ignorant but am on my 3rd vette and never heard of this problem...good reason for this forum!
