oil change
Old 05-08-2013, 10:24 AM
blackgs11
blackgs11's Avatar
Default oil change
Hello all, being a new owner of a Vette I have a question....will regular car ramps accomodate the low clearance of a 2011 GS without scraping the front end or the rear? She is due for an oil change and need some guidance. I have seen low profile ramps but I figured I would ask before I try.
Old 05-08-2013, 10:27 AM
Luster
Luster's Avatar
The low profile ramps are pricey, but "regular" ramps are too steep. Your plastic splitter will scrape.
You can build some helper extensions out of 2x12's with angled cuts on the ends, if they are 2 layers deep.
Or do what I do... Low clearance jack with jackstand and done in 10 minutes.
Old 05-08-2013, 10:29 AM
Knowklew
Knowklew's Avatar
St. Jude Donor '13-'14
No...
Old 05-08-2013, 10:37 AM
blackgs11
blackgs11's Avatar
Thanks for the quick response and the help!
Old 05-08-2013, 10:49 AM
weathermaker
weathermaker's Avatar
As mentioned, drive up onto a couple of 2X8/10/12s. Whatever you got before getting onto ramps. You can get as fancy as you want.
Old 05-08-2013, 12:08 PM
vindicator
vindicator's Avatar
You can go to the raceramps.com site and they give good info on what size ramp will fit your car. I ve used the old metal ramps, made wood ramps. Tomorrrow I am ordering 57 inch race ramps for my 13 GS. There is an e bay vender selling new 57 inch race ramps for $228 inc shipping
Old 05-08-2013, 02:29 PM
iclick
iclick's Avatar
I used 2x8" boards I had lying around to make a set of ramps using a circular saw and my rudimentary skills at woodworking. Cost: $0. They work perfect, raising the car just enough to allow eiither of my floor jacks (regular or low-profile) to slide under the front, but they aren't needed for the rear with either jack. See this thread for more info and earlier links on jacking.
Old 05-08-2013, 02:44 PM
funymuny
funymuny's Avatar
https://s6-us2.ixquick-proxy.com/do/...ury%2Flane.jpg
I made some ramps along the lines of these. My modifications were using 2 x 6 boards, three as the ribs. I covered with 3/4" plywood. Also, I did not cut the variable pitch incline. The boards go from about 1/2" to 5 5/8" over about 4 feet. I made a 12" flat spot at the end of the ramp. Should have made that a little larger but it still works. Very solid.
Old 05-08-2013, 02:45 PM
Jitsu
Jitsu's Avatar
http://forums.corvetteforum.com/c6-c...il-change.html
Old 05-08-2013, 03:00 PM
dozing4dollars
dozing4dollars's Avatar
I just did my first oil change on my 2012 Coupe and used my drive up Rhino ramps.
As other owners have suggested, I placed a short 2 x 12 just prior to each Rhino ramp to elevate the car just slightly as it hit the ramp entrance. It seemed to work just fine both going up and down the ramp. YMMV
Since I use these same ramps for my other cars, I did not want to purchase a special set for the Vette.
Old 05-08-2013, 03:28 PM
0Fred@ReverseLogic
Former Vendor
Fred@ReverseLogic's Avatar
eBay is an expensive place to buy Race Ramps due to the exorbitant fees. After the current $20 factory rebate you can get the 2-PC 56" ramps for well under $200 at www.reverselogic.us
Old 05-08-2013, 04:55 PM
360Rocket
360Rocket's Avatar
St. Jude Donor '12-'13-'14
Race Ramps are how much?
Just put the finishing touches on a set of 360Rocket Ramps! $5.97 of pressure treated 2 x 6 and some wood screws. Finished off with a couple of coats of Thompsons water seal.
Old 05-08-2013, 05:14 PM
tjthomps5629
tjthomps5629's Avatar
How many of you jack up the rear to level the car during an oil change?
Old 05-08-2013, 05:20 PM
SSWEET
SSWEET's Avatar
If you have a low profile floor jack that will fit under your Vette. save your self the carpentry work.....just use the jack to lift your car and slide the ramps under the tires......so simple a caveman....you know the drill......
Old 05-08-2013, 06:02 PM
R&L's C6
Support Corvetteforum!
R&L's C6's Avatar
Received 1,250 Likes on 706 Posts
I made a pair just like those and here's a little tip. I put them behind the front wheels and back onto them. That way, the tails of the ramps are in front of the car and they dont get in the way when crawling under the car to change oil.
Old 05-08-2013, 06:37 PM
billyboy47
billyboy47's Avatar
St. Jude Donor '17
i use the 10" high race ramps never touch the car when driving up them. i paid quite a bit but don't forget, it's a vette and worth it.
Old 05-08-2013, 07:45 PM
Mad*Max
Mad*Max's Avatar
Received 1,500 Likes on 817 Posts
I don't
To oil change
Old 05-08-2013, 07:46 PM
Mad*Max
Mad*Max's Avatar
I use regular ramps on my coupe, not sure about the GS
Old 05-08-2013, 08:46 PM
R&L's C6
R&L's C6's Avatar
Old 05-08-2013, 09:00 PM
MKenM
MKenM's Avatar
St. Jude Donor '12-'13-'14-'15-'16-'17-'18,'21
I jack up the drivers side slide my oil catch pan under. Remove the filter then the plug. Let the car down which lets the balance of the oil in the pan drain out. Walk away have a beer come back in 10 put the new filter in and put the plug back in. 10-12 minutes and done. No ramps no lining things up.
Quick Reply: oil change
