Getting bugs off of a car-
Any citrus product works pretty well. WD40 also works. Soaking them for a few minutes with soap and water helps them come right off. No need to get too fancy.
RejeX also helps keep the bugs from sticking in the first place. But if they do stick they seem to wash off easier.
Like others are saying, I applied a sealer before the trip to Bowling Green. I used rejex, based on the common references to it on this forum. Then, each eening when we stopped, I just sprayed the citrus cleaner on the bugs, waited a minute and wiped them off. Then rinsed with water.
So - it seems my plan was really this: sealer, followed by frequent spray and wipe.
On my Harley's windshield, I spray hydrogen peroxide on the bugs, let it sit for about 30 seconds, and they come right off. I use it on the paint too. It seems very safe as I have been doing it for a couple of years with no problems. Haven't tried it on the vette yet, but I have no concerns using it.
You don't have to spend money on products. All you need to do is soak them. Let the water run over the hood or area about 30 seconds then go clean your wheels or something that takes about 5-10 minutes. Then, just scrub them away with a car sponge with car wash detergent mixed with a little elbow grease. If you need some elbow grease you can go buy some at any local gym.
Only on rare occasions, I've had to let soak more than once. Using soap and water only saves you from having to wax after the use of the other bug removal chemicals.
#33
I do the same thing I do with the fairing on my motorcycle, a towel soaked in hot water. Apply the wet towel (it sticks well cause its wet) let sit for awhile and as you remove it, rub it around and collect the bug splatter. Really quite easy and costs nothing.
#34
My sister in law told me about using a wet dryer fabric softner rag for bugs a few weeks ago. It works, really works. I was having a very hard time getting bugs off the wife's car and remembered her telling me about it. Got one out of the box, wet it and it removed the bugs better then anything I have ever used. I did have to wash the car afterwards. It did leave a film on the paint but washed right off.
#35
I just use a detail spray and a used dryer sheet to get bugs off. Works like a charm. Just make sure the sheet is completely used up, no stiffness in the sheet at all.
#37
So reading this thread makes me wonder what is conatined in a dryer sheet that it works to remove bug splats from your cars? It a a chemical thing? Is it the make up the sheet fibers? And most importantly is whatever it is OK for your car's finish and wax?
#39
Imagine what a "new" dryer sheet might do to your finish...
Just sayin'...
#40
I've always used dryer sheets to clean the hard water streaks on my shower doors at home, but never thought of using it on the car too.
Great idea!
A Google search says it also worked really well for cleaning up brake dust on car wheels, awesome!
Great idea!
