Gah...need a solid
Old 05-20-2013, 10:19 PM
Pb82 Ronin
Pb82 Ronin's Avatar
Default Gah...need a solid
Does anyone know where I can get the link to the complete list of TSB's for C6 corvettes? I searched for about an hour and couldn't find it...but I saw it on here about 3 months ago. My damn airbag light keeps staying on as well as various other electrical gremlins and they're quite irritating. Help a brother out. 2007 ZO6.
Old 05-20-2013, 10:22 PM
not08crmanymore
not08crmanymore's Avatar
Look up top in the FAQ section.
Old 05-20-2013, 10:23 PM
mpuzach
mpuzach's Avatar
Received 1,190 Likes on 594 Posts
I can't help you regarding the TSBs but the airbag light is almost certainly due to a loose or damaged connector under your driver's seat. It's a common problem that a dealer should be able to easily diagnose and correct.
Old 05-20-2013, 10:25 PM
ptroxx
ptroxx's Avatar
Location: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Not sure if this will help
http://forums.corvetteforum.com/c6-c...arch-list.html
Old 05-21-2013, 12:37 AM
RadarP3C
RadarP3C's Avatar
Correcting the loose connection is a very easy DYI fix. I followed VET4LES's advice and problem solved.
From VET4LES's post in another thread.....
That's my C6 above and I thought those took care of my problem but it turned out the ones attached to the back of the seat frame ultimately solved the problem.
This is the connector for the inboard seat belt pre-tensioner. I took the car to the dealer many times with no luck. They finally said a code was set for the drivers pre-tensioner. It was replaced under GMPP and all was good for six months or so. The intermittent light returned. I found these connectors at the back of the seats frame and zip tied them and have had no problem since. My thought is the loose connection caused the code. I'm sure that was close to several years ago.
Old 05-22-2013, 12:49 PM
Pb82 Ronin
Pb82 Ronin's Avatar
Sweet...thanks guys. Will try today
To Gah...need a solid
Quick Reply: Gah...need a solid
