Windows freaking out Help??
I just started up car this morning on my 08. The first thing that happened was the window kept indexing itself and I could not get it to stop for about 5 mins. It was only the driver side but when I went to get out of the car the door would not open, I had to use the overide. After I got out and shut the door the window went nuts again and the door would once again not open. I did notice that if I used the remote and depress the lock button the indexing would stop but it made a strange pulsing noise as the window sealed up.
Any clues or point me in the correct direction to find out would be appreciated
Steve
Steve
Replace the door touchpad. You can try cleaning it, but it's only $15 for a new one.
Corrosion of the touchpad is a common problem, especially in warm & humid areas.
Of course, it might be something else...
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,831 Likes
2015 C7 of the Year Finalist
I just bought it 3 months ago with 7000 miles on it. Very possible, I will look into this if the new pads dont work, Thank you
