Dash Speaker
Old 05-26-2013, 11:16 AM
vet55
Support Corvetteforum!
vet55's Avatar
Default Dash Speaker
Been reading through all the threads I can find
on the dash speaker grille rattle. I have it and
plan to pad it somehow.
Two questions.
1) Is there a TSB on this?
2) Is most everyone disconnecting
the dash speaker?
Thx ahead!
Old 05-26-2013, 11:32 AM
09C6inWA
09C6inWA's Avatar
I had the center speaker disconnected when I had new speakers installed. As other members here have said; the separation is improved and having the crappy GM speaker in the mix would defeat the purpose of installing new speakers.
Old 05-26-2013, 11:52 AM
Grzldvt1
Grzldvt1's Avatar
Take it out as it just screws up the sound. It was GM's attempt at equalizing the sound for both the passenger and the driver, but the biggest success of the middle speaker was to screw up the sound stage and eliminate any hope of decent stereo separation.
Old 05-30-2013, 07:59 AM
vet55
vet55's Avatar
Ok, here's my idea. What if we
did a speaker grill cover in
reverse?
Get some high grade speaker
grille cloth. Cover the under
side of the speaker grill.
Glue the cloth to the bottom
of the original grill.
Leave cut outs for the clips.
The cloth pads the underside
of the grill and cuts out the
rattle. It also looks good from
the visual side of the grill.
Got this: http://www.parts-express.com/pe/show...number=260-332
Opinions?
Old 05-30-2013, 12:15 PM
truth.b
truth.b's Avatar
I'm actually considering replacing the center speaker with a Kicker DS35 but I'm not sure it will fit. I sometimes take conference calls in the car on the way to work via Bluetooth, so for me the center speaker serves a good purpose. OP in your search have you found any other option associated with the center speaker besides disconnecting it?
Old 05-30-2013, 12:23 PM
ATC399
ATC399's Avatar
Are you sure its coming from the speaker?
Old 05-30-2013, 01:02 PM
vet55
vet55's Avatar
I am sure it is coming from the grill cover
of the speaker. I assume the speaker is locked
into place.
But I hold down the grill cover and the rattle
stops. Let go, rattle returns.
I have not looked at speaker options as I
don't think the speaker is defected.
To Dash Speaker
Quick Reply: Dash Speaker
