DIC oil level trivia
Old 05-17-2013, 12:27 PM
06 C6 vert
06 C6 vert's Avatar
Default DIC oil level trivia
Does the oil level alert prompt pop at 1 quart low or 1 1/2 quarts low ?
any thoughts on this ?
I have had it go off on both !but what's the factory default ?
55k miles on 06. Amazing car , very quick. It finally broke in all the way.
Old 05-17-2013, 12:43 PM
purvistechie
purvistechie's Avatar
My thought is that you actually let your car get so low on oil that an idiot light goes on? (ok, so it's not an idiot light, but you know what I mean). Any car that I run hard, I keep a pretty close eye on all fluids. Actually I keep a pretty good eye on that for all cars I drive.
Old 05-17-2013, 06:10 PM
Snake.Oiler
Support Corvetteforum!
Snake.Oiler's Avatar
St. Jude Donor '13,'14,'15,'16,'18,'19-'20,'22,'24
Why is the engine getting so low on oil? That's the question I'd be asking.
Old 05-17-2013, 08:52 PM
MikeERWNC
MikeERWNC's Avatar
I do know it is annoying if that sensor wire ever comes loose under the car.
I haven't lost any oil and I have 79K on mine.
I measure what I take out and it is always 5.5 qt.
I will say I swapped to Molie1 10w40 this week and I saw 30MPG today after a 484 mile trip.
Monday's trip was 738 miles and I barely was able to get 28MPG.
Changed the oil Tuesday.
The engine feels smoother and more solid.
Usually after a fresh 5w30 change the engine just felt loose- tired.
Old 05-17-2013, 09:31 PM
EVRose
EVRose's Avatar
I'm gonna go with 10w40 on my next change too. With outside temps constantly over 105° in the summer I think it will be better.
Old 05-17-2013, 10:29 PM
Patman
Patman's Avatar
Received 1,920 Likes on 1,192 Posts
Other factors caused that 2 MPG increase in MPG because there is absolutely no way that going to a thicker oil is going to give you better MPG. In fact, it probably wouldn't even hurt the MPG by all that much either (maybe 0.5 MPG under identical conditions) Having a strong headwind or tailwind on either of those trips was the most likely culprit for the big change in fuel economy.
Old 05-18-2013, 12:28 AM
06 C6 vert
06 C6 vert's Avatar
The usage does seem to be a little odd, but on the other hand it makes sense. I will get into a groove of very spirited driving for a week or so at a time. Very high revs and lots of W O T. seems like lots of oil was being sucked through the PCV system ,maybe this explains why the sudden loss of oil.
For those of you that just cruise your Vettes you won't see any oil Usage no question, Unless your engine is jacked up.
Lots of chatter about oil catch cans ive noticed on the forum.
Even some of the other high-end brands are starting to adapt catch cans.
To DIC oil level trivia
Quick Reply: DIC oil level trivia
