streaks after washing/drying
After washing my vette, I have tried drying it with a chamois and have also tried a micro-fiber towel, and either way it always leaves streaks. Only waxing the car afterwards will remove the streaks and I don't want to wax it every time I wash it. Also, which is better--paste wax or spray-on wax? The spray-on is, of course, much faster, but is it just as good? Thanks!
Get yourself a Master Blaster and blow dry it....no streaks.
http://www.autogeek.net/mema.html?pr...FcNaMgodXDoAQw
Some folks lose their minds, but i bought an electric leaf blower at wally worls for @ $40 and have been using it for years. works great and wasn't $300
☠☣☢ Semper Ebrius ☢☣☠
The Mr. Clean spot free carwash system had a filter that removed impurities from the water, allowing it to dry spot-free, but it's been discontinued. This was better because it eliminated an entire step of running something across your car and, therefore, minimized scratching.
You might still be able to find one and some filters for it on eBay, however. But any sort of filtering system that softens the water would work.
Location: S/W ,Fla-Ohio State Football isn't a matter of life or death,Its Much More serious than that
Received 1,142 Likes
I started out with an electric leaf blower and while it worked ok, there is no comparison to the Master Blaster. Its a ton easier to get the mirrors, door jams, wheels, wheel wells, taillights, and all the other little nooks and crannies with the Master Blaster.
Just my opinion and it works good for me. I was wash and dry the car in sections, top, one side, than the other side, front, back, then 1 wheel at a time. I use a 2 cobra waffle weave towels, 1 for intial wipe and the 2nd for final dry. Wheels I wash and then use the small master blaster to blow out calipers and lugnut holes and almost dry wheels and finish with small cobra waffle weave. Then I take the small master blaster and go around car blowing out side markers and all the other crevices while wiping off the blown out trapped water with the waffle weave. Never a streak or water spot. And besides the little extra time on the whells, the car body process goes real fast!
Years past with other vehicles I've tried chamois, cotton towels and you name it and the cobra waffle weave is friggin awesome, I'll use nothing else anymore. Also the small master blaster works great because it isn't $300 (alot cheaper) and more portable when I hit the stool next to each wheel (wash bucket, master blaster and waffle weave over the shoulder, then on to the next wheel).
If you use a leaf blower make sure that's all you use it for. Mine will also suck up and mulch leaves. Doing that puts crud on the fan and you can guess what happens next time you go from suck to blow.....
I was really disappointed to see them discontinue this product. It was great. Ebay had some of the soap and filters but they got too expensive. Now I use a shamwow type of towel to soak up the excess water and then Capt Richards Best spray detailer to finish it off. Air blowers are probably good to remove excess water but I am usually too lazy to drag it out.
Make sure you are not using much detergent if any when washing cloths, and definitely no fabric softener.
Either that or Meguiars Quik Wax.
I wash, leaf blower ($40 Home Depot device), dry with microfiber towels, then detail spray at the least, Quik Wax if I have a little more time, and Rejex every few months.
The leaf blower is a big help in getting massive amount of water that's pooled up on the car, as well as the cracks and side lights that hold water in them. Also real good for drying the wheels because of all the nooks and crannies.
Streaks
I use car wash from a spray bottle directly on the car. This is a true wash and not a detail. I purchased it in Autogeek and it works well on a dirty car. Leaves the finish shiny and no water streaking. No blow drying or hose either.
